[NEED HELP] "zpool import" pool after reainstalling Freenas.
cacheabuley
Hello everyone!
Hopefully you can help me with my current problem.
I had to shutdown my Freenas server and after turning it back on my 2 boot USB's failed (mirrored SanDisk USB's)
Shutdown was perfomed via web GUI.
After reinstalling Freenas 11.2-U7 on M.2 SSD in usb enclosure I couldn't import my pool into newly installed Freenas.
No hardware changes were done, except new SSD in USB enclosure as boot device was added.
GUI doesn't see any pools.
"zpool import" does nothing
I upgraded to 11.3-U3 in hopes it will help, but still can't see any pools.
I tried "zpool import pool" with "no such pool available" as result.
"zpool import -f" or "zpool import -d" does nothing
There are 2 errors in web GUI:
I would appreciate any help and tips.
Hardware:
  • Motherboard make and model
    • Gigabyte H270-N WiFi
  • CPU make and model
    • Intel i3 6100
  • RAM quantity
    • 32gb DDR4 Non-ECC. Corsair LPX.
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives
    • 5 x 2TB drives from WD, RaidZ2 configuration
    • da0 is boot drive.
    • da1 is failed USB from SanDisk
    • Another SanDisk not appearing at all.
  • Hard disk controllers
    • SATA - integrated into motherboard
  • Network cards
    • 2 x Intel® GbE LAN chips (10/100/1000 Mbit) - integrated into motherboarb
"zpool list" output:
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP  HEALTH  ALTROOT
freenas-boot   118G  3.37G   115G        -         -      -     2%  1.00x  ONLINE  -
"zpool status" output:
  pool: freenas-boot
 state: ONLINE
  scan: none requested
    freenas-boot  ONLINE       0     0     0
      da0p2     ONLINE       0     0     0
errors: No known data errors
"gpart status" output:
ada0p1      OK  ada0
ada0p2      OK  ada0
ada1p1      OK  ada1
ada1p2      OK  ada1
ada2p1      OK  ada2
ada2p2      OK  ada2
ada3p1      OK  ada3
ada3p2      OK  ada3
ada4p1      OK  ada4
ada4p2      OK  ada4
 da0p1      OK  da0
 da0p2      OK  da0
"gpart list" output:
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 3907029127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,4abe2362-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000)
   rawuuid: 4abe2362-8d02-11e8-b2db-1c1b0d62205b
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada0p2
   Mediasize: 1998251364352 (1.8T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(2,GPT,4acbe598-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808)
   rawuuid: 4acbe598-8d02-11e8-b2db-1c1b0d62205b
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 1998251364352
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 3907029127
   start: 4194432
Consumers:
1. Name: ada0
   Mediasize: 2000398934016 (1.8T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 3907029127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,4d5199b3-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000)
   rawuuid: 4d5199b3-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(2,GPT,4d5dfc30-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808)
   rawuuid: 4d5dfc30-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 3907029127
   start: 4194432
Consumers:
1. Name: ada1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 3907029127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,4f9f71fa-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000)
   rawuuid: 4f9f71fa-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(2,GPT,4fac651e-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808)
   rawuuid: 4fac651e-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 3907029127
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 3907029127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,51ffb5eb-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000)
   rawuuid: 51ffb5eb-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(2,GPT,520caee9-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808)
   rawuuid: 520caee9-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 3907029127
   start: 4194432
Consumers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: ada4
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 3907029127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: ada4p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,5479093a-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000)
   rawuuid: 5479093a-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada4p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(2,GPT,54859e07-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808)
   rawuuid: 54859e07-8d02-11e8-b2db-1c1b0d62205b
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 3907029127
   start: 4194432
Consumers:
1. Name: ada4
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 250069639
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
   Mediasize: 272629760 (260M)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   efimedia: HD(1,GPT,ce713b07-c381-11ea-8af6-1c1b0d62205b,0x28,0x82000)
   rawuuid: ce713b07-c381-11ea-8af6-1c1b0d62205b
   rawtype: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
   label: (null)
   length: 272629760
   offset: 20480
   type: efi
   index: 1
   end: 532519
   start: 40
2. Name: da0p2
   Mediasize: 127758499840 (119G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   efimedia: HD(2,GPT,ce99e128-c381-11ea-8af6-1c1b0d62205b,0x82028,0xedf8000)
   rawuuid: ce99e128-c381-11ea-8af6-1c1b0d62205b
   label: (null)
   length: 127758499840
   offset: 272650240
   type: freebsd-zfs
   index: 2
   end: 250060839
   start: 532520
Consumers:
1. Name: da0
   Mediasize: 128035676160 (119G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Samuel Tai
First: breathe, and relax. Take a look at this other thread that has some ideas to try.
cacheabuley
Good morning and thank you for sharing this link.
I red through it and it seems some of the solutions might be applied to my situation.
What was done so far:
  • Swapped sata cables 2-3 times, tried to use brand new cables.
  • Swapped PSU
  • Swapped motherboard and CPU
  • Swapped OS boot media and installed FreeNAS 11.3-U4.
  • Added extra storage to retrieve data from disks in case I won't be able to import pool.
  • Run 'smartctl -t long" on all 5 disks
  • Run MemTest 86, 4 passes with no errors. Still using same RAM sticks
I got more warning messages like this FreeNAS UI:
3 out of 5 disks gave me some sort of errrors in S.M.A.R.T. tests:
Disk 1:
Errors summary:
  • Self-test execution status: (121) The previous self-test completed havin the read element of the test failed.
  • 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 5
  • 197 Current_Pending_Sector -O--CK 200 200 000 - 3
  • 198 Offline_Uncorrectable ----CK 200 200 000 - 3
  • 200 Multi_Zone_Error_Rate ---R-- 200 199 000 - 3
  • SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
  • Extended offline Completed: read failure 90% 16049 3907012680
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      ( 121)    The previous self-test completed having
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  3 Spin_Up_Time            POS--K   171   167   021    -    6433
  4 Start_Stop_Count        -O--CK   100   100   000    -    118
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   078   078   000    -    16060
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    62
192 Power-Off_Retract_Count -O--CK   200   200   000    -    32
193 Load_Cycle_Count        -O--CK   001   001   000    -    1689472
194 Temperature_Celsius     -O---K   109   102   000    -    41
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
Device Error Count: 1
    CR     = Command Register
    FEATR  = Features Register
    COUNT  = Count (was: Sector Count) Register
    LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
    LH     = LBA High (was: Cylinder High) Register    ]   LBA
    LM     = LBA Mid (was: Cylinder Low) Register      ] Register
    LL     = LBA Low (was: Sector Number) Register     ]
    DV     = Device (was: Device/Head) Register
    DC     = Device Control Register
    ER     = Error register
    ST     = Status register
Error 1 [0] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  04 -- 61 00 00 00 00 ff ab 00 00 00 00
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  ea 00 00 00 00 00 00 00 00 00 00 40 00     00:01:51.040  FLUSH CACHE EXT
  ea 00 00 00 00 00 00 00 00 00 00 40 00     00:01:29.329  FLUSH CACHE EXT
  ea 00 00 00 00 00 00 00 00 00 00 40 00     00:01:07.616  FLUSH CACHE EXT
  ea 00 00 00 00 00 00 00 00 00 00 40 00     00:00:45.902  FLUSH CACHE EXT
  ea 00 00 00 00 00 00 00 00 00 00 40 00     00:00:24.189  FLUSH CACHE EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed: read failure       90%     16049         3907012680
# 2  Short offline       Completed: read failure       90%     16048         3907012680
# 3  Short offline       Completed: read failure       90%     15922         3907012680
# 4  Short offline       Completed: read failure       90%     15898         3907012680
# 5  Short offline       Completed: read failure       90%     15874         3907012680
# 6  Short offline       Completed: read failure       90%     15850         3907012680
# 7  Short offline       Completed: read failure       90%     15826         3907012680
# 8  Short offline       Completed: read failure       90%     15802         3907012680
# 9  Short offline       Completed: read failure       90%     15778         3907012680
#10  Short offline       Completed: read failure       90%     15754         3907012680
#11  Short offline       Completed: read failure       10%     15730         3907012680
#12  Short offline       Completed: read failure       10%     15706         3907012680
#13  Short offline       Completed: read failure       90%     15682         3907012680
#14  Short offline       Completed: read failure       90%     15658         3907012680
#15  Short offline       Completed: read failure       90%     15634         3907012680
#16  Short offline       Completed: read failure       90%     15610         3907012680
#17  Short offline       Completed: read failure       90%     15586         3907012680
#18  Short offline       Completed: read failure       90%     15562         3907012680
Disk 2:
Error summary:
  • 197 Current_Pending_Sector -O--CK 200 200 000 - 29
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   253   173   021    -    991
  4 Start_Stop_Count        -O--CK   098   098   000    -    2897
  9 Power_On_Hours          -O--CK   040   040   000    -    44520
 12 Power_Cycle_Count       -O--CK   100   100   000    -    50
192 Power-Off_Retract_Count -O--CK   200   200   000    -    20
193 Load_Cycle_Count        -O--CK   001   001   000    -    800439
194 Temperature_Celsius     -O---K   100   099   000    -    50
198 Offline_Uncorrectable   ----CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%     44520         -
# 2  Short offline       Completed without error       00%     44252         -
# 3  Short offline       Completed without error       00%     44228         -
# 4  Short offline       Completed without error       00%     44204         -
# 5  Short offline       Completed without error       00%     44180         -
# 6  Short offline       Completed without error       00%     44156         -
# 7  Short offline       Completed without error       00%     44132         -
# 8  Short offline       Completed without error       00%     44108         -
# 9  Short offline       Completed without error       00%     44084         -
#10  Short offline       Completed without error       00%     44060         -
#11  Short offline       Completed without error       00%     44036         -
#12  Short offline       Completed without error       00%     44012         -
#13  Short offline       Completed without error       00%     43988         -
#14  Short offline       Completed without error       00%     43964         -
#15  Short offline       Completed without error       00%     43940         -
#16  Short offline       Completed without error       00%     43916         -
#17  Short offline       Completed without error       00%     43892         -
#18  Short offline       Completed without error       00%     43868         -
Disk 3:
Error summary:
    Device Error Count: 18
                    been run.
  3 Spin_Up_Time            POS--K   168   166   021    -    6558
  4 Start_Stop_Count        -O--CK   100   100   000    -    273
  9 Power_On_Hours          -O--CK   013   013   000    -    63549
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    181
192 Power-Off_Retract_Count -O--CK   200   200   000    -    135
193 Load_Cycle_Count        -O--CK   001   001   000    -    3316470
194 Temperature_Celsius     -O---K   105   100   000    -    45
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
Error 18 [17] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  40 -- 51 00 04 00 00 e8 e0 88 ac 40 00  Error: UNC 4 sectors at LBA = 0xe8e088ac = 3907029164
  25 00 00 00 04 00 00 e8 e0 88 ac 40 00     00:02:04.814  READ DMA EXT
  25 00 00 00 04 00 00 e8 e0 88 ac 40 00     00:02:04.802  READ DMA EXT
  25 00 00 00 04 00 00 e8 e0 88 ac 40 00     00:02:04.781  READ DMA EXT
  25 00 00 00 04 00 00 e8 e0 88 ac 40 00     00:02:04.760  READ DMA EXT
  2f 00 00 00 01 00 00 00 00 00 10 40 00     00:02:04.760  READ LOG EXT
Error 17 [16] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  60 00 04 00 78 00 00 e8 e0 88 ac 40 00     00:02:04.621  READ FPDMA QUEUED
Error 16 [15] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  60 00 04 00 70 00 00 e8 e0 84 ac 40 00     00:02:04.599  READ FPDMA QUEUED
Error 15 [14] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  60 00 04 00 68 00 00 00 00 04 00 40 00     00:02:04.597  READ FPDMA QUEUED
Error 14 [13] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  40 -- 51 00 01 00 00 e8 e0 88 ac 40 00  Error: UNC at LBA = 0xe8e088ac = 3907029164
  60 00 01 00 60 00 00 00 00 02 00 40 00     00:02:04.574  READ FPDMA QUEUED
  25 00 00 00 01 00 00 e8 e0 88 af 40 00     00:02:04.562  READ DMA EXT
Error 13 [12] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  40 -- 51 00 01 00 00 e8 e0 88 af 40 00  Error: UNC 1 sectors at LBA = 0xe8e088af = 3907029167
  25 00 00 00 01 00 00 e8 e0 88 af 40 00     00:02:04.550  READ DMA EXT
  25 00 00 00 01 00 00 e8 e0 88 af 40 00     00:02:04.529  READ DMA EXT
  25 00 00 00 01 00 00 e8 e0 88 af 40 00     00:02:04.509  READ DMA EXT
  2f 00 00 00 01 00 00 00 00 00 10 40 00     00:02:04.508  READ LOG EXT
Error 12 [11] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  60 00 01 00 58 00 00 e8 e0 88 af 40 00     00:02:04.375  READ FPDMA QUEUED
Error 11 [10] occurred at disk power-on lifetime: 47447 hours (1976 days + 23 hours)
  60 00 01 00 50 00 00 e8 e0 87 af 40 00     00:02:03.991  READ FPDMA QUEUED
# 1  Extended offline    Completed without error       00%     63549         -
# 2  Short offline       Completed without error       00%     63342         -
# 3  Short offline       Completed without error       00%     63318         -
# 4  Short offline       Completed without error       00%     63294         -
# 5  Short offline       Completed without error       00%     63270         -
# 6  Short offline       Completed without error       00%     63246         -
# 7  Short offline       Completed without error       00%     63222         -
# 8  Short offline       Completed without error       00%     63198         -
# 9  Short offline       Completed without error       00%     63174         -
#10  Short offline       Completed without error       00%     63150         -
#11  Short offline       Completed without error       00%     63126         -
#12  Short offline       Completed without error       00%     63102         -
#13  Short offline       Completed without error       00%     63078         -
#14  Short offline       Completed without error       00%     63054         -
#15  Short offline       Completed without error       00%     63030         -
#16  Short offline       Completed without error       00%     63006         -
#17  Short offline       Completed without error       00%     62982         -
#18  Short offline       Completed without error       00%     62958         -
'zpool import' command doesn't show anything. Pool not even identified.
I want to see what options I have:
  • try to fix disc errors
  • remove some disks and see if something will change
  • run 'zpool import' with diffrenet options like -fF, -D, -X or similar. I don't know from where to start.
  • try to retrieve data from disks
  • maybe run clonezilla and copy disk to another disk? I have sspare 2 x 4 tb seagates
I will apprecieate any tip.
Samuel Tai
The load cycle counts are all very high on these 3 disks. Were you spinning them down on idle? This introduces accelerated wear on disks, and isn't recommended in a server environment.
From what I can see, you've been extremely unlucky, and suffered 3 failed disks simultaneously.
cacheabuley
Samuel,
Thank you for quick reply. I red different opinions on that topic. However it seems that it's better to stop disks on idle. Lesson learned.
What I can do in this case? Possibly I have some options?
Samuel Tai
You're unfortunately now forced to perform disk recovery. What you can do is to pull all the drives from the pool, and attempt to image them to RAW files suitable for recovery via Klennet. This tool has a pretty good track record here. Then save the disks in case you need to use a recovery service. Once the disks are all pulled, you can delete the pool, and build a new pool using fresh disks.
