cacheabuley
- Jul 11, 2020
Hello everyone!
Hopefully you can help me with my current problem.
I had to shutdown my Freenas server and after turning it back on my 2 boot USB's failed (mirrored SanDisk USB's)
Shutdown was perfomed via web GUI.
After reinstalling Freenas 11.2-U7 on M.2 SSD in usb enclosure I couldn't import my pool into newly installed Freenas.
No hardware changes were done, except new SSD in USB enclosure as boot device was added.
GUI doesn't see any pools.
"zpool import" does nothing
I upgraded to 11.3-U3 in hopes it will help, but still can't see any pools.
I tried "zpool import pool" with "no such pool available" as result.
"zpool import -f" or "zpool import -d" does nothing
There are 2 errors in web GUI:
I would appreciate any help and tips.
Hardware:
"zpool status" output:
"gpart status" output:
"gpart list" output:
Hardware:
- Motherboard make and model
- Gigabyte H270-N WiFi
- CPU make and model
- Intel i3 6100
- RAM quantity
- 32gb DDR4 Non-ECC. Corsair LPX.
- Hard drives, quantity, model numbers, and RAID configuration, including boot drives
- 5 x 2TB drives from WD, RaidZ2 configuration
- da0 is boot drive.
- da1 is failed USB from SanDisk
- Another SanDisk not appearing at all.
- Hard disk controllers
- SATA - integrated into motherboard
- Network cards
- 2 x Intel® GbE LAN chips (10/100/1000 Mbit) - integrated into motherboarb
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT freenas-boot 118G 3.37G 115G - - - 2% 1.00x ONLINE -
pool: freenas-boot
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
ada0p1 OK ada0 ada0p2 OK ada0 ada1p1 OK ada1 ada1p2 OK ada1 ada2p1 OK ada2 ada2p2 OK ada2 ada3p1 OK ada3 ada3p2 OK ada3 ada4p1 OK ada4 ada4p2 OK ada4 da0p1 OK da0 da0p2 OK da0
Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,4abe2362-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000) rawuuid: 4abe2362-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,4acbe598-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808) rawuuid: 4acbe598-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,4d5199b3-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000) rawuuid: 4d5199b3-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,4d5dfc30-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808) rawuuid: 4d5dfc30-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,4f9f71fa-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000) rawuuid: 4f9f71fa-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,4fac651e-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808) rawuuid: 4fac651e-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,51ffb5eb-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000) rawuuid: 51ffb5eb-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,520caee9-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808) rawuuid: 520caee9-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada4 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029127 first: 40 entries: 128 scheme: GPT Providers: 1. Name: ada4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,5479093a-8d02-11e8-b2db-1c1b0d62205b,0x80,0x400000) rawuuid: 5479093a-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada4p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(2,GPT,54859e07-8d02-11e8-b2db-1c1b0d62205b,0x400080,0xe8a08808) rawuuid: 54859e07-8d02-11e8-b2db-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada4 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 250069639 first: 40 entries: 128 scheme: GPT Providers: 1. Name: da0p1 Mediasize: 272629760 (260M) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 efimedia: HD(1,GPT,ce713b07-c381-11ea-8af6-1c1b0d62205b,0x28,0x82000) rawuuid: ce713b07-c381-11ea-8af6-1c1b0d62205b rawtype: c12a7328-f81f-11d2-ba4b-00a0c93ec93b label: (null) length: 272629760 offset: 20480 type: efi index: 1 end: 532519 start: 40 2. Name: da0p2 Mediasize: 127758499840 (119G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 efimedia: HD(2,GPT,ce99e128-c381-11ea-8af6-1c1b0d62205b,0x82028,0xedf8000) rawuuid: ce99e128-c381-11ea-8af6-1c1b0d62205b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 127758499840 offset: 272650240 type: freebsd-zfs index: 2 end: 250060839 start: 532520 Consumers: 1. Name: da0 Mediasize: 128035676160 (119G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2
