Hi there,
My System is:
Build FreeNAS-11.1-U6
Platform Intel(R) Atom(TM) CPU C2758 @ 2.40GHz
Memory 16318MB ECC RAM
since Wednesday I've have received this error message 2 times:
smartmontools shows this:
zpool status gives me this
Is this caused by a bad sata cable or even worse, is the ssd of the mirror about to fail soon.
Due to noise issues and not having a spare room for the small server I cannot use a hdd instead of ssds for the moment.
Looking forward to hear from you.
Thank you!
My System is:
freenas.local kernel log messages: (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 88 f2 73 40 1b 00 00 01 00 00 (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error (ada0:ahcich0:0:0:0): Retrying command (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 88 f3 73 40 1b 00 00 00 00 00 (ada0:ahcich0:0:0:0): CAM status: Uncorrectable parity/CRC error (ada0:ahcich0:0:0:0): Retrying command -- End of security output --
root@freenas:~ # smartctl -a /dev/ada0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: WD Blue PC SSD Device Model: WDC WDS500G1B0A-00H9H0 Serial Number: 165115423345 LU WWN Device Id: 5 001b44 4a6b6d988 Firmware Version: X41100WD User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Nov 2 16:19:10 2018 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 4 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 --- Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 --- Old_age Always - 12785 12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 37 165 Block_Erase_Count 0x0032 100 100 --- Old_age Always - 77530012 166 Minimum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 1 167 Max_Bad_Blocks_per_Die 0x0032 100 100 --- Old_age Always - 18 168 Maximum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 5 169 Total_Bad_Blocks 0x0032 100 100 --- Old_age Always - 331 170 Grown_Bad_Blocks 0x0032 100 100 --- Old_age Always - 0 171 Program_Fail_Count 0x0032 100 100 --- Old_age Always - 0 172 Erase_Fail_Count 0x0032 100 100 --- Old_age Always - 0 173 Average_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 2 174 Unexpected_Power_Loss 0x0032 100 100 --- Old_age Always - 5 184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 --- Old_age Always - 0 188 Command_Timeout 0x0032 100 100 --- Old_age Always - 22 194 Temperature_Celsius 0x0022 071 071 --- Old_age Always - 29 (Min/Max 19/71) 199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0 230 Media_Wearout_Indicator 0x0032 100 100 --- Old_age Always - 0x0240001c0240 232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 100 233 NAND_GB_Written_TLC 0x0032 100 100 --- Old_age Always - 1366 234 NAND_GB_Written_SLC 0x0032 100 100 --- Old_age Always - 10041 241 Total_Host_GB_Written 0x0030 253 253 --- Old_age Offline - 9382 242 Total_Host_GB_Read 0x0030 253 253 --- Old_age Offline - 55527 244 Temp_Throttle_Status 0x0032 000 100 --- Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 12758 - # 2 Short offline Completed without error 00% 12758 - Selective Self-tests/Logging not supported
root@freenas:~ # zpool status -v pool: data state: ONLINE scan: scrub repaired 0 in 0 days 00:13:31 with 0 errors on Tue Oct 9 04:13:31 2018 config: NAME STATE READ WRITE CKSUM data ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 gptid/96175e2b-209f-11e8-b60c-0cc47a6ad1ac ONLINE 0 0 0 gptid/96a91bf8-209f-11e8-b60c-0cc47a6ad1ac ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:00:21 with 0 errors on Thu Nov 1 03:45:21 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 ada2p2 ONLINE 0 0 0 errors: No known data errors
Thank you!
