Hi there,
WebUI shows an alert for /dev/ada0: Device: /dev/ada0, 3 Currently unreadable (pending) sectors.
I ran a long / extended SMART test for that disk. The result showed no errors.
After the test run i scrubed the whole pool -> no known data errors, pool is ONLINE.
A couple of hours later i ran another SMART long test. This is the result:
Still no errors ("Completed without error").
So do i need to replace that disk with a new one? This hdd is part of a mirror, not a raid(z).
Thanks for our help.
[root@midgard] ~# smartctl -a /dev/ada0 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p25 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green Device Model: WDC WD15EADS-00P8B0 Serial Number: WD-WMAVU0093944 LU WWN Device Id: 5 0014ee 0017c9170 Firmware Version: 01.00A01 User Capacity: 1,500,301,910,016 bytes [1.50 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Sat Feb 13 20:45:33 2016 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (32400) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 370) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 171 169 021 Pre-fail Always - 6408 4 Start_Stop_Count 0x0032 087 087 000 Old_age Always - 13409 5 Reallocated_Sector_Ct 0x0033 195 195 140 Pre-fail Always - 35 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 18599 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2287 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 540 193 Load_Cycle_Count 0x0032 162 162 000 Old_age Always - 115983 194 Temperature_Celsius 0x0022 114 094 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 198 198 000 Old_age Always - 2 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 4 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 18599 - # 2 Short offline Completed without error 00% 18597 - # 3 Extended offline Completed without error 00% 18595 - # 4 Short offline Completed without error 00% 18590 - # 5 Extended offline Completed without error 00% 18562 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@midgard] ~# dmesg | tail -n 10 epair0b: link state changed to UP re0: link state changed to DOWN epair0a: promiscuous mode enabled ng_ether_ifnet_arrival_event: can't re-name node epair0b re0: link state changed to UP ahcich0: Timeout on slot 16 port 0 ahcich0: is 00000000 cs 00010000 ss 00000000 rs 00010000 tfd c0 serr 00000000 cmd 0000d017 (ada0:ahcich0:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 (ada0:ahcich0:0:0:0): CAM status: Command timeout (ada0:ahcich0:0:0:0): Retrying command
