jammersplace
- Aug 29, 2011
Device /dev/ad4 - FUJITSU MHW2020BH/00930013
Device Model: FUJITSU MHW2020BH
Serial Number: NZ0GT7128GYN
Firmware Version: 00930013
User Capacity: 20,003,880,960 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 3b
Local Time is: Tue Aug 30 02:11:57 2011 UTC
SMART support is: Disabled
SMART Disabled. Use option -s with argument 'on' to enable it.
Device /dev/da0 - ATA ST2000DL003-9VT1 CC32
Device Model: ST2000DL003-9VT166
Serial Number: 5YD25RX5
Firmware Version: CC32
User Capacity: 2,000,398,934,016 bytes
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 623) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
SCT capabilities: (0x30b7) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 30344
3 Spin_Up_Time 0x0003 094 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 71
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 074 060 030 Pre-fail Always - 25610247
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3143
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 74
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 5
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 069 055 045 Old_age Always - 31 (Min/Max 31/31)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 70
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 71
194 Temperature_Celsius 0x0022 031 045 000 Old_age Always - 31 (0 20 0 0)
195 Hardware_ECC_Recovered 0x001a 036 004 000 Old_age Always - 30344
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 132280697752645
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1593623385
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 405821536
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 3133 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
