Seagate 8TB NAS HDDs
Robert Smith
Does anybody have experience with Seagate 8TB NAS drives?
I just got one (part number ST8000VN0002). It runs a little hot, but I gather they run hot for everybody.
More alarmingly, I am having trouble consistently completing self-tests. Sporadically, a test would get stuck and not move anywhere until the drive is powered down.
Short and conveyance tests get stuck on 90%, and long tests get stuck on 10%.
If I abort the test without powering the drive down, the consequent tests will always get stuck.
If I power the drive down, and then turn it back up, the next test may run fine, or may get stuck again.
This is not due to the drive being accessed as I have not partitioned or created any volumes yet.
The SMART parameters are all good, and the drive reports that it is healthy.
No firmware updates are currently available.
smartctl 6.5 2016-05-07 r4318 [x86_64-w64-mingw32-win10] (sf-6.5-1)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:  ST8000VN0002-1Z8112
Serial Number:  [redacted]
LU WWN Device Id: 5 000c50 091566a8e
Firmware Version: SC60
User Capacity:  8,001,563,222,016 bytes [8.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  7200 rpm
Form Factor:  3.5 inches
Device is:  Not in smartctl database [for details use: -P showall]
ATA Version is:  ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Thu Jul 14 13:55:06 2016 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
  was completed without error.
Self-test execution status:  ( 249) Self-test routine in progress...
  90% of test remaining.
data collection:  (  567) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  1) minutes.
Extended self-test routine
recommended polling time:  ( 743) minutes.
Conveyance self-test routine
recommended polling time:  (  2) minutes.
SCT capabilities:  (0x50bd) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x000f  084  071  044  Pre-fail  Always  -  243449864
  3 Spin_Up_Time  0x0003  085  085  000  Pre-fail  Always  -  0
  4 Start_Stop_Count  0x0032  100  100  020  Old_age  Always  -  9
  5 Reallocated_Sector_Ct  0x0033  100  100  010  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x000f  063  061  045  Pre-fail  Always  -  2036135
  9 Power_On_Hours  0x0032  100  100  000  Old_age  Always  -  23 (51 84 0)
10 Spin_Retry_Count  0x0013  100  100  097  Pre-fail  Always  -  0
12 Power_Cycle_Count  0x0032  100  100  020  Old_age  Always  -  3
184 End-to-End_Error  0x0032  100  100  099  Old_age  Always  -  0
187 Reported_Uncorrect  0x0032  100  100  000  Old_age  Always  -  0
188 Command_Timeout  0x0032  099  099  000  Old_age  Always  -  8590065666
189 High_Fly_Writes  0x003a  100  100  000  Old_age  Always  -  0
190 Airflow_Temperature_Cel 0x0022  063  056  040  Old_age  Always  -  37 (Min/Max 27/42)
191 G-Sense_Error_Rate  0x0032  100  100  000  Old_age  Always  -  168
192 Power-Off_Retract_Count 0x0032  100  100  000  Old_age  Always  -  0
193 Load_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  12
194 Temperature_Celsius  0x0022  037  044  000  Old_age  Always  -  37 (0 25 0 0 0)
195 Hardware_ECC_Recovered  0x001a  006  006  000  Old_age  Always  -  243449864
197 Current_Pending_Sector  0x0012  100  100  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0010  100  100  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x003e  200  200  000  Old_age  Always  -  0
240 Head_Flying_Hours  0x0000  100  253  000  Old_age  Offline  -  6 (196 101 0)
241 Total_LBAs_Written  0x0000  100  253  000  Old_age  Offline  -  3612828032
242 Total_LBAs_Read  0x0000  100  253  000  Old_age  Offline  -  245454450
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline  Self-test routine in progress 90%  23  -
# 2  Short offline  Completed without error  00%  22  -
# 3  Extended offline  Aborted by host  90%  20  -
# 4  Extended offline  Aborted by host  90%  3  -
# 5  Conveyance offline  Completed without error  00%  3  -
# 6  Short offline  Completed without error  00%  3  -
# 7  Short offline  Aborted by host  10%  3  -
# 8  Conveyance offline  Aborted by host  10%  3  -
# 9  Conveyance offline  Interrupted (host reset)  10%  2  -
#10  Short offline  Aborted by host  10%  2  -
#11  Short offline  Completed without error  00%  0  -
#12  Extended offline  Aborted by host  90%  0  -
#13  Short offline  Completed without error  00%  0  -
#14  Conveyance offline  Completed without error  00%  0  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
Stux
Could be an issue unique to the individual drive?
Robert Smith
The issue could definitely be unique to the drive; I just got one to see how I like it.
No firmware updates are yet available for this model.
I had run the tests under Windows 10. I have just restarted everything from the begging under Ubuntu 16.04; I will let y'all know in a few days.
Thank you.
Robert Smith
Well, I do not see this weird stuck self-tests issue under Ubuntu. I do not know who do blame here; I had run hard drive tests under Windows for many years without any problems, but this is the first time I run the tests under Windows 10. A different hard drive (HGST with data) does not get stuck tests...
The 8TB Seagate drive appears to work fine under Ubuntu. Badblocks, no problem.
It does run hot under load (45 Celsius with good cooling).
Also the SMART ID# 191 (G-Sense_Error_Rate) keeps on climbing by about a thousand per day, not sure what that is about. Again this is something I see other people report in reviews; so maybe it is normal.
I am going to put ZFS on on the drive and see what happens.
Local Time is:  Fri Jul 15 19:23:28 2016 PDT
AAM feature is:  Unavailable
APM feature is:  Unavailable
Rd look-ahead is: Enabled
Write cache is:  Enabled
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
Self-test execution status:  (  0) The previous self-test routine completed
  been run.
  command.
  power-saving mode.
ID# ATTRIBUTE_NAME  FLAGS  VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate  POSR--  082  067  044  -  154848909
  3 Spin_Up_Time  PO----  086  085  000  -  0
  4 Start_Stop_Count  -O--CK  100  100  020  -  18
  5 Reallocated_Sector_Ct  PO--CK  100  100  010  -  0
  7 Seek_Error_Rate  POSR--  070  061  045  -  10472448
  9 Power_On_Hours  -O--CK  100  100  000  -  52 (148 42 0)
 10 Spin_Retry_Count  PO--C-  100  100  097  -  0
 12 Power_Cycle_Count  -O--CK  100  100  020  -  7
184 End-to-End_Error  -O--CK  100  100  099  -  0
187 Reported_Uncorrect  -O--CK  100  100  000  -  0
188 Command_Timeout  -O--CK  100  099  000  -  8590065666
189 High_Fly_Writes  -O-RCK  100  100  000  -  0
190 Airflow_Temperature_Cel -O---K  070  055  040  -  30 (Min/Max 29/30)
191 G-Sense_Error_Rate  -O--CK  100  100  000  -  1090
192 Power-Off_Retract_Count -O--CK  100  100  000  -  0
193 Load_Cycle_Count  -O--CK  100  100  000  -  39
194 Temperature_Celsius  -O---K  030  045  000  -  30 (0 25 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-  006  006  000  -  154848909
197 Current_Pending_Sector  -O--C-  100  100  000  -  0
198 Offline_Uncorrectable  ----C-  100  100  000  -  0
199 UDMA_CRC_Error_Count  -OSRCK  200  200  000  -  0
240 Head_Flying_Hours  ------  100  253  000  -  28 (246 76 0)
241 Total_LBAs_Written  ------  100  253  000  -  19240881200
242 Total_LBAs_Read  ------  100  253  000  -  12734101760
  ||||||_ K auto-keep
  |||||__ C event count
  ||||___ R error rate
  |||____ S speed/performance
  ||_____ O updated online
  |______ P prefailure warning
General Purpose Log Directory Version 1
SMART  Log Directory Version 1 [multi-sector log support]
Address  Access  R/W  Size  Description
0x00  GPL,SL  R/O  1  Log Directory
0x01  SL  R/O  1  Summary SMART error log
0x02  SL  R/O  5  Comprehensive SMART error log
0x03  GPL  R/O  5  Ext. Comprehensive SMART error log
0x04  GPL,SL  R/O  8  Device Statistics log
0x06  SL  R/O  1  SMART self-test log
0x07  GPL  R/O  1  Extended self-test log
0x08  GPL  R/O  2  Power Conditions log
0x09  SL  R/W  1  Selective self-test log
0x0c  GPL  R/O  2048  Pending Defects log
0x10  GPL  R/O  1  SATA NCQ Queued Error log
0x11  GPL  R/O  1  SATA Phy Event Counters log
0x13  GPL  R/O  1  SATA NCQ Send and Receive log
0x15  GPL  R/W  1  SATA Rebuild Assist log
0x21  GPL  R/O  1  Write stream error log
0x22  GPL  R/O  1  Read stream error log
0x24  GPL  R/O  512  Current Device Internal Status Data log
0x30  GPL,SL  R/O  9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W  16  Host vendor specific log
0xa1  GPL,SL  VS  24  Device vendor specific log
0xa2  GPL  VS  8160  Device vendor specific log
0xa6  GPL  VS  192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS  136  Device vendor specific log
0xab  GPL  VS  1  Device vendor specific log
0xad  GPL  VS  16  Device vendor specific log
0xb0  GPL  VS  9048  Device vendor specific log
0xbe-0xbf  GPL  VS  65535  Device vendor specific log
0xc1  GPL,SL  VS  16  Device vendor specific log
0xc3  GPL,SL  VS  8  Device vendor specific log
0xd1  GPL  VS  264  Device vendor specific log
0xd2  GPL  VS  10000  Device vendor specific log
0xd4  GPL  VS  2048  Device vendor specific log
0xda  GPL,SL  VS  1  Device vendor specific log
0xe0  GPL,SL  R/W  1  SCT Command/Status
0xe1  GPL,SL  R/W  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Conveyance offline  Completed without error  00%  44  -
# 2  Short offline  Completed without error  00%  44  -
# 3  Conveyance offline  Completed without error  00%  25  -
# 4  Short offline  Completed without error  00%  24  -
# 5  Vendor (0x50)  Fatal or unknown error  90%  24  0
# 6  Short offline  Completed without error  00%  24  -
# 7  Extended offline  Interrupted (host reset)  00%  24  -
# 8  Short offline  Completed without error  00%  22  -
# 9  Extended offline  Aborted by host  90%  20  -
#10  Extended offline  Aborted by host  90%  3  -
#11  Conveyance offline  Completed without error  00%  3  -
#12  Short offline  Completed without error  00%  3  -
#13  Short offline  Aborted by host  10%  3  -
#14  Conveyance offline  Aborted by host  10%  3  -
#15  Conveyance offline  Interrupted (host reset)  10%  2  -
#16  Short offline  Aborted by host  10%  2  -
#17  Short offline  Completed without error  00%  0  -
#18  Extended offline  Aborted by host  90%  0  -
#19  Short offline  Completed without error  00%  0  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
SCT Status Version:  3
SCT Version (vendor specific):  522 (0x020a)
SCT Support Level:  1
Device State:  Active (0)
Current Temperature:  29 Celsius
Power Cycle Min/Max Temperature:  29/29 Celsius
Lifetime  Min/Max Temperature:  27/45 Celsius
Under/Over Temperature Limit Count:  0/1
SCT Temperature History Version:  2
Temperature Sampling Period:  3 minutes
Temperature Logging Interval:  59 minutes
Min/Max recommended Temperature:  0/ 0 Celsius
Min/Max Temperature Limit:  0/ 0 Celsius
Temperature History Size (Index):  128 (38)
Index  Estimated Time  Temperature Celsius
  39  2016-07-10 13:39  ?  -
 ...  ..( 88 skipped).  ..  -
  0  2016-07-14 05:10  ?  -
  1  2016-07-14 06:09  27  ********
  2  2016-07-14 07:08  ?  -
  3  2016-07-14 08:07  41  **********************
  4  2016-07-14 09:06  39  ********************
  5  2016-07-14 10:05  29  **********
  6  2016-07-14 11:04  ?  -
  7  2016-07-14 12:03  28  *********
  8  2016-07-14 13:02  32  *************
  9  2016-07-14 14:01  29  **********
  10  2016-07-14 15:00  27  ********
  11  2016-07-14 15:59  43  ************************
  12  2016-07-14 16:58  ?  -
  13  2016-07-14 17:57  43  ************************
  14  2016-07-14 18:56  ?  -
  15  2016-07-14 19:55  42  ***********************
  16  2016-07-14 20:54  44  *************************
  17  2016-07-14 21:53  44  *************************
  18  2016-07-14 22:52  45  **************************
  19  2016-07-14 23:51  45  **************************
  20  2016-07-15 00:50  45  **************************
  21  2016-07-15 01:49  44  *************************
  22  2016-07-15 02:48  44  *************************
  23  2016-07-15 03:47  43  ************************
  24  2016-07-15 04:46  42  ***********************
 ...  ..(  2 skipped).  ..  ***********************
  27  2016-07-15 07:43  42  ***********************
  28  2016-07-15 08:42  43  ************************
 ...  ..(  5 skipped).  ..  ************************
  34  2016-07-15 14:36  43  ************************
  35  2016-07-15 15:35  ?  -
  36  2016-07-15 16:34  38  *******************
  37  2016-07-15 17:33  ?  -
  38  2016-07-15 18:32  29  **********
SCT Error Recovery Control:
  Read:  70 (7.0 seconds)
  Write:  70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size  Value Flags Description
0x01  =====  =  =  ===  == General Statistics (rev 1) ==
0x01  0x008  4  7  ---  Lifetime Power-On Resets
0x01  0x010  4  52  ---  Power-on Hours
0x01  0x018  6  19240881200  ---  Logical Sectors Written
0x01  0x020  6  58748761  ---  Number of Write Commands
0x01  0x028  6  12734101760  ---  Logical Sectors Read
0x01  0x030  6  34459271  ---  Number of Read Commands
0x01  0x038  6  1468355009681  ---  Date and Time TimeStamp
0x03  =====  =  =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4  29  ---  Spindle Motor Power-on Hours
0x03  0x010  4  24  ---  Head Flying Hours
0x03  0x018  4  39  ---  Head Load Events
0x03  0x020  4  0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4  0  ---  Read Recovery Attempts
0x03  0x030  4  0  ---  Number of Mechanical Start Failures
0x03  0x038  4  0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4  0  ---  Number of High Priority Unload Events
0x04  =====  =  =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4  0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4  2  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =  =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1  29  ---  Current Temperature
0x05  0x010  1  39  ---  Average Short Term Temperature
0x05  0x018  1  -  ---  Average Long Term Temperature
0x05  0x020  1  45  ---  Highest Temperature
0x05  0x028  1  25  ---  Lowest Temperature
0x05  0x030  1  40  ---  Highest Average Short Term Temperature
0x05  0x038  1  33  ---  Lowest Average Short Term Temperature
0x05  0x040  1  -  ---  Highest Average Long Term Temperature
0x05  0x048  1  -  ---  Lowest Average Long Term Temperature
0x05  0x050  4  0  ---  Time in Over-Temperature
0x05  0x058  1  70  ---  Specified Maximum Operating Temperature
0x05  0x060  4  0  ---  Time in Under-Temperature
0x05  0x068  1  0  ---  Specified Minimum Operating Temperature
0x06  =====  =  =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4  23  ---  Number of Hardware Resets
0x06  0x010  4  2  ---  Number of ASR Events
0x06  0x018  4  0  ---  Number of Interface CRC Errors
  |||_ C monitored condition met
  ||__ D supports DSN
  |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID  Size  Value  Description
0x000a  2  2  Device-to-host register FISes sent due to a COMRESET
0x0001  2  0  Command failed due to ICRC error
0x0003  2  0  R_ERR response for device-to-host data FIS
0x0004  2  0  R_ERR response for host-to-device data FIS
0x0006  2  0  R_ERR response for device-to-host non-data FIS
0x0007  2  0  R_ERR response for host-to-device non-data FIS
tvsjr
G-Sense Error Rate increments due to external physical shock. What sort of chassis do you have these drives mounted in? Are they secure, not getting vibrated, etc.?
Robert Smith
For testing it was the only spinning drive in a Lenovo TS140, right under the front fan.
The 8TB sucker vibrates itself. It does not subjectively feel too bad for a 7200 drive.
Robert Smith
I wrote 2 TB to the disk, and scrubbed the pool after that. No problems. Also, no problems with self tests under FreeNAS, so far.
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
ATA Version is:  ACS-3 (unknown minor revision code: 0x006d)
Local Time is:  Sun Jul 17 13:09:21 2016 PDT
  been run.
  command.
  power-saving mode.
  1 Raw_Read_Error_Rate  0x000f  100  067  044  Pre-fail  Always  -  63928
  3 Spin_Up_Time  0x0003  086  085  000  Pre-fail  Always  -  0
  4 Start_Stop_Count  0x0032  100  100  020  Old_age  Always  -  19
  7 Seek_Error_Rate  0x000f  073  061  045  Pre-fail  Always  -  21998315
  9 Power_On_Hours  0x0032  100  100  000  Old_age  Always  -  93 (5 97 0)
 12 Power_Cycle_Count  0x0032  100  100  020  Old_age  Always  -  8
188 Command_Timeout  0x0032  100  099  000  Old_age  Always  -  8590065680
190 Airflow_Temperature_Cel 0x0022  054  045  040  Old_age  Always  -  46 (Min/Max 32/55)
191 G-Sense_Error_Rate  0x0032  100  100  000  Old_age  Always  -  1636
193 Load_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  56
194 Temperature_Celsius  0x0022  046  055  000  Old_age  Always  -  46 (0 25 0 0 0)
195 Hardware_ECC_Recovered  0x001a  100  005  000  Old_age  Always  -  63928
199 UDMA_CRC_Error_Count  0x003e  200  200  000  Old_age  Always  -  23
240 Head_Flying_Hours  0x0000  100  253  000  Old_age  Offline  -  227023381332025
241 Total_LBAs_Written  0x0000  100  253  000  Old_age  Offline  -  30697027100
242 Total_LBAs_Read  0x0000  100  253  000  Old_age  Offline  -  17442823700
No Errors Logged
# 1  Extended offline  Completed without error  00%  85  -
# 2  Extended offline  Aborted by host  80%  69  -
# 3  Short offline  Completed without error  00%  67  -
# 4  Conveyance offline  Completed without error  00%  44  -
# 5  Short offline  Completed without error  00%  44  -
# 6  Conveyance offline  Completed without error  00%  25  -
# 7  Short offline  Completed without error  00%  24  -
# 8  Vendor (0x50)  Fatal or unknown error  90%  24  0
# 9  Short offline  Completed without error  00%  24  -
#10  Extended offline  Interrupted (host reset)  00%  24  -
#11  Short offline  Completed without error  00%  22  -
#12  Extended offline  Aborted by host  90%  20  -
#13  Extended offline  Aborted by host  90%  3  -
#14  Conveyance offline  Completed without error  00%  3  -
#15  Short offline  Completed without error  00%  3  -
#16  Short offline  Aborted by host  10%  3  -
#17  Conveyance offline  Aborted by host  10%  3  -
#18  Conveyance offline  Interrupted (host reset)  10%  2  -
#19  Short offline  Aborted by host  10%  2  -
#20  Short offline  Completed without error  00%  0  -
#21  Extended offline  Aborted by host  90%  0  -
1 of 1 failed self-tests are outdated by newer successful extended offline self-test # 1
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
For now I am going to assume that the initial self tests problem is Windows 10 fault.
Temperature and vibrations is something to keep an eye on.
TXAG26
Are these 8TB Seagate NAS drives really 7200 rpm? I thought the Seagate NAS line was 5900 rpm and the Western Digital Red NAS were 5400 rpm? Or are you running Pro's?
