SmallGuy
 - Jun 7, 2013
I have Recently RMA a WD30EFRX drive because it was noisy (sound to be unbalanced). I have replace the failed disc with the recertified replacement drive provided, using the web GUI (offline and replace buttons).
The status of the pool was healthy after the resilvering (and is already healthy).
Few time later some kernel messages have appeared:
There is less than 16GB on the pool, and nothing important.
I have proceed a scrub and nothing to notice:
Then I have proceed to a short follwing by a long SMART test and all seems to be fine:
Find also the gpart list (I don't have enough knoledge to extract any information from that):
I have try to change the SATA cable and I have test the RAM with Memetest and nothing to notice.
I don't understand what's happend, and what to do now.
Has somebody any idea?
Thanks.
Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 d8 a7 eb 40 32 00 00 00 00 00 Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): CAM status: ATA Status Error Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): RES: 41 10 d8 a7 eb 40 32 00 00 00 00 Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): Retrying command
[root@freenas] ~# zpool status
  pool: Volume1
 state: ONLINE
  scan: scrub repaired 0 in 0h6m with 0 errors on Thu Dec 12 07:16:28 2013
        Volume1                                         ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/a734066f-61ba-11e3-a751-ac220b7596c7  ONLINE       0     0     0
            gptid/4254e25c-4670-11e3-9600-ac220b7596c7  ONLINE       0     0     0
            gptid/42be8a92-4670-11e3-9600-ac220b7596c7  ONLINE       0     0     0
errors: No known data errorsThen I have proceed to a short follwing by a long SMART test and all seems to be fine:
[root@freenas] ~# smartctl -a -q noserial /dev/ada0
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Dec 12 18:44:37 2013 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (38880) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 390) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       3
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       48
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       3
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       609
194 Temperature_Celsius     0x0022   122   118   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%        44         -
# 2  Short offline       Completed without error       00%        37         -
# 3  Extended offline    Completed without error       00%        11         -
# 4  Conveyance offline  Completed without error       00%         1         -
# 5  Short offline       Completed without error       00%         1         -
If Selective self-test is pending on power-up, resume after 0 minute delay.Find also the gpart list (I don't have enough knoledge to extract any information from that):
[root@freenas] ~# gpart list Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: a7227556-61ba-11e3-a751-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: a734066f-61ba-11e3-a751-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 424207af-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 4254e25c-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 42aaa81e-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 42be8a92-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 15633407 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 8004304896 (7.5G) Sectorsize: 512 Mode: r2w1e4 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1
Thanks.
