Hi All,
Fairly new user to FreeNAS and semi novice linux user here who has made a terrible mistake - out of my own stupidity I've managed to wipe one of the disks in my zpool - long story but basically I made a mistake...
The most important data was backed up however there is other data which would be nice to recover if possible.
I'm using FreeNAS-9.1.1-RELEASE-x64 (a752d35), reading from similar issues on this forum I believe you'll want the below data.
So, what are my chances of recovering my data?
gpart list
gpart show
zpool import
smartctl -a -q noserial /dev/ada1
camcontrol devlist
glabel status
gpart list
[root@fileserver] ~# gpart list Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 488397167 first: 63 entries: 4 scheme: MBR Providers: 1. Name: ada0s1 Mediasize: 254803968 (243M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1048576 Mode: r0w0e0 attrib: active rawtype: 131 length: 254803968 offset: 1048576 type: linux-data index: 1 end: 499711 start: 2048 2. Name: ada0s2 Mediasize: 249802261504 (232G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 256900096 Mode: r0w0e0 rawtype: 5 length: 249802261504 offset: 256900096 type: ebr index: 2 end: 488396799 start: 501758 Consumers: 1. Name: ada0 Mediasize: 250059350016 (232G) Sectorsize: 512 Mode: r0w0e0 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r1w1e1 rawuuid: e45f0c0b-354c-11e3-81c0-009c02a7f4d2 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 998057319936 (929G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: e474d040-354c-11e3-81c0-009c02a7f4d2 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 998057319936 offset: 2147549184 type: freebsd-zfs index: 2 end: 1953525134 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r1w1e2 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525167 first: 63 entries: 4 scheme: MBR Providers: 1. Name: ada2s1 Mediasize: 209715200 (200M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1048576 Mode: r0w0e0 attrib: active rawtype: 131 length: 209715200 offset: 1048576 type: linux-data index: 1 end: 411647 start: 2048 2. Name: ada2s2 Mediasize: 4060086272 (3.8G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 210763776 Mode: r0w0e0 rawtype: 131 length: 4060086272 offset: 210763776 type: linux-data index: 2 end: 8341503 start: 411648 3. Name: ada2s3 Mediasize: 995933290496 (927G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 4270850048 Mode: r0w0e0 rawtype: 131 length: 995933290496 offset: 4270850048 type: linux-data index: 3 end: 1953523711 start: 8341504 Consumers: 1. Name: ada2 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r0w0e0 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525167 first: 63 entries: 4 scheme: MBR Providers: 1. Name: ada3s1 Mediasize: 1000202241024 (931G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r0w0e0 rawtype: 66 length: 1000202241024 offset: 32256 type: ms-ldm-data index: 1 end: 1953520064 start: 63 Consumers: 1. Name: ada3 Mediasize: 1000204886016 (931G) Sectorsize: 512 Mode: r0w0e0 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7831551 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 4009754624 (3.8G) Sectorsize: 512 Mode: r2w1e4 Geom name: ada0s2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 487895041 first: 0 entries: 7744365 scheme: EBR Providers: 1. Name: ada0s5 Mediasize: 249802260480 (232G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 256901120 Mode: r0w0e0 rawtype: 142 length: 249802260480 offset: 1024 type: linux-lvm index: 1 end: 487895041 start: 0 Consumers: 1. Name: ada0s2 Mediasize: 249802261504 (232G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 256900096 Mode: r0w0e0 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1
gpart show
[root@fileserver] ~# gpart show
=>       63  488397105  ada0  MBR  (232G)
         63       1985        - free -  (992k)
       2048     497664     1  linux-data  [active]  (243M)
     499712       2046        - free -  (1M)
     501758  487895042     2  ebr  (232G)
  488396800        368        - free -  (184k)
=>        34  1953525101  ada1  GPT  (931G)
          34          94        - free -  (47k)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  1949330703     2  freebsd-zfs  (929G)
=>        63  1953525105  ada2  MBR  (931G)
        2048      409600     1  linux-data  [active]  (200M)
      411648     7929856     2  linux-data  (3.8G)
     8341504  1945182208     3  linux-data  (927G)
  1953523712        1456        - free -  (728k)
=>        63  1953525105  ada3  MBR  (931G)
          63  1953520002     1  ms-ldm-data  (931G)
  1953520065        5103        - free -  (2.5M)
=>     63  7831489  da0  MBR  (3.8G)
       63  1930257    1  freebsd  [active]  (942M)
  1930320       63       - free -  (31k)
  1930383  1930257    2  freebsd  (942M)
  3860640     3024    3  freebsd  (1.5M)
  3863664    41328    4  freebsd  (20M)
  3904992  3926560       - free -  (1.9G)
=>        0  487895042  ada0s2  EBR  (232G)
          0  487895042       1  linux-lvm  (232G)
=>      0  1930257  da0s1  BSD  (942M)
        0       16         - free -  (8.0k)
       16  1930241      1  !0  (942M)
zpool import
[root@fileserver] ~# zpool import
  pool: media
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
        devices and try again.
  see: http://illumos.org/msg/ZFS-8000-6X
        media                                        UNAVAIL  missing device
          gptid/e474d040-354c-11e3-81c0-009c02a7f4d2  ONLINE
        Additional devices are known to be part of this pool, though their
        exact configuration cannot be determined.
[root@fileserver] ~# smartctl -a -q noserial /dev/ada1
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:    SAMSUNG SpinPoint F3
Device Model:    SAMSUNG HD103SJ
Firmware Version: 1AJ10001
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
ATA Version is:  ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Thu Jan 30 18:23:30 2014 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      (  0) The previous self-test routine completed
                                        been run.
data collection:                ( 9060) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (  2) minutes.
Extended self-test routine
recommended polling time:        ( 151) minutes.
SCT capabilities:              (0x003f) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x002f  100  100  051    Pre-fail  Always      -      0
  2 Throughput_Performance  0x0026  252  252  000    Old_age  Always      -      0
  3 Spin_Up_Time            0x0023  071  069  025    Pre-fail  Always      -      8985
  4 Start_Stop_Count        0x0032  074  074  000    Old_age  Always      -      27258
  5 Reallocated_Sector_Ct  0x0033  252  252  010    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x002e  252  252  051    Old_age  Always      -      0
  8 Seek_Time_Performance  0x0024  252  252  015    Old_age  Offline      -      0
  9 Power_On_Hours          0x0032  100  100  000    Old_age  Always      -      4566
10 Spin_Retry_Count        0x0032  252  252  051    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  252  252  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      577
191 G-Sense_Error_Rate      0x0022  100  100  000    Old_age  Always      -      4
192 Power-Off_Retract_Count 0x0022  252  252  000    Old_age  Always      -      0
194 Temperature_Celsius    0x0002  064  055  000    Old_age  Always      -      33 (Min/Max 14/45)
195 Hardware_ECC_Recovered  0x003a  100  100  000    Old_age  Always      -      0
196 Reallocated_Event_Count 0x0032  252  252  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0032  252  252  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0030  252  252  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0036  100  100  000    Old_age  Always      -      1
200 Multi_Zone_Error_Rate  0x002a  100  100  000    Old_age  Always      -      1
223 Load_Retry_Count        0x0032  252  252  000    Old_age  Always      -      0
225 Load_Cycle_Count        0x0032  072  072  000    Old_age  Always      -      283825
SMART Error Log Version: 1
ATA Error Count: 1
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 536 hours (22 days + 8 hours)
  ER ST SC SN CL CH DH
  84 51 de 00 a4 00 e0  Error: ICRC, ABRT 222 sectors at LBA = 0x0000a400 = 41984
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  c8 00 00 de a4 d7 ec 00      00:20:27.392  READ DMA
  c8 00 00 de a3 d7 ec 00      00:20:27.392  READ DMA
  c8 00 00 de a2 d7 ec 00      00:20:27.392  READ DMA
  c8 00 00 de a1 d7 ec 00      00:20:27.392  READ DMA
  c8 00 00 de a0 d7 ec 00      00:20:27.392  READ DMA
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
    1        0        0  Completed [00% left] (0-65535)
camcontrol devlist
[root@fileserver] ~# camcontrol devlist <VB0250EAVER HPG7> at scbus0 target 0 lun 0 (ada0,pass0) <SAMSUNG HD103SJ 1AJ10001> at scbus1 target 0 lun 0 (ada1,pass1) <Hitachi HDT721010SLA360 ST6OA31B> at scbus2 target 0 lun 0 (ada2,pass2) <ST31000528AS CC35> at scbus3 target 0 lun 0 (ada3,pass3) <ASUS DRW-2014L1T 1.00> at scbus4 target 1 lun 0 (pass4,cd0) <SMI USB DISK 3000> at scbus6 target 0 lun 0 (da0,pass5) [root@fileserver] ~#
glabel status
[root@fileserver] ~# glabel status
                                      Name  Status  Components
gptid/e474d040-354c-11e3-81c0-009c02a7f4d2    N/A  ada1p2
                                ntfs/media    N/A  ada3s1
                            ufs/FreeNASs3    N/A  da0s3
                            ufs/FreeNASs4    N/A  da0s4
                            ufs/FreeNASs1a    N/A  da0s1a
