SmallGuy
- Jun 7, 2013
I have Recently RMA a WD30EFRX drive because it was noisy (sound to be unbalanced). I have replace the failed disc with the recertified replacement drive provided, using the web GUI (offline and replace buttons).
The status of the pool was healthy after the resilvering (and is already healthy).
Few time later some kernel messages have appeared:
There is less than 16GB on the pool, and nothing important.
I have proceed a scrub and nothing to notice:
Then I have proceed to a short follwing by a long SMART test and all seems to be fine:
Find also the gpart list (I don't have enough knoledge to extract any information from that):
I have try to change the SATA cable and I have test the RAM with Memetest and nothing to notice.
I don't understand what's happend, and what to do now.
Has somebody any idea?
Thanks.
Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 d8 a7 eb 40 32 00 00 00 00 00 Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): CAM status: ATA Status Error Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): ATA status: 41 (DRDY ERR), error: 10 (IDNF ) Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): RES: 41 10 d8 a7 eb 40 32 00 00 00 00 Dec 11 08:05:18 freenas kernel: (ada0:ahcich0:0:0:0): Retrying command
[root@freenas] ~# zpool status pool: Volume1 state: ONLINE scan: scrub repaired 0 in 0h6m with 0 errors on Thu Dec 12 07:16:28 2013 config: NAME STATE READ WRITE CKSUM Volume1 ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/a734066f-61ba-11e3-a751-ac220b7596c7 ONLINE 0 0 0 gptid/4254e25c-4670-11e3-9600-ac220b7596c7 ONLINE 0 0 0 gptid/42be8a92-4670-11e3-9600-ac220b7596c7 ONLINE 0 0 0 errors: No known data errors
[root@freenas] ~# smartctl -a -q noserial /dev/ada0 smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (AF) Device Model: WDC WD30EFRX-68EUZN0 Firmware Version: 80.00A80 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Thu Dec 12 18:44:37 2013 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (38880) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 390) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 48 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 609 194 Temperature_Celsius 0x0022 122 118 000 Old_age Always - 28 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 44 - # 2 Short offline Completed without error 00% 37 - # 3 Extended offline Completed without error 00% 11 - # 4 Conveyance offline Completed without error 00% 1 - # 5 Short offline Completed without error 00% 1 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
[root@freenas] ~# gpart list Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: a7227556-61ba-11e3-a751-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: a734066f-61ba-11e3-a751-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 424207af-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 4254e25c-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 42aaa81e-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 42be8a92-4670-11e3-9600-ac220b7596c7 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 15633407 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 8004304896 (7.5G) Sectorsize: 512 Mode: r2w1e4 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1
Thanks.
