somethingweird
- Jan 27, 2022
I don't remember if there was any option to burn in hard drive via gui - Any thoughts?
Then shouldn't there be one (eventually??)There is no GUI option.
However, for those who buy packaged servers with hardware support iXsystems, the original and replacement drives likely come pre-burned in. So it would not likely be a feature the Enterprise customers would need.
No, because there is no generally agreed standard for burning-in drives. It is the user's responsibility to chose a procedure which suits him.Then shouldn't there be one (eventually??)
badblocks -w
, doing that outside of the NAS at least prevents erasing an active pool member by mistake.I'd argue that the time it takes for the test to complete is a feature, not a bug. Put the drive in a non-ventilated external SATA dock and after 4-10 days of h2testw, the HDD will have run hotter & harder than it likely will inside the NAS. Less expensive docks only offer USB, the more expensive ones offer eSATA as well. Such docks are also useful for drive wipes. There is also a mac-native version of h2testw called F3XSwift. I have yet to use that as I preferred running h2testw via Parallels. Linux folk likely would prefer badblocks.Yes it takes literally an extra 4 to 10 days to put my new hard drives in my NAS, however I know then, that while they might still break, they at least worked when I put them in and they may not have "a bad bit on them" near the 2/3 mark or something, which has stung me, twice before.
Quoting Valerie Henson in this article:Yes it takes literally an extra 4 to 10 days to put my new hard drives in my NAS, however I know then, that while they might still break, they at least worked when I put them in and they may not have "a bad bit on them" near the 2/3 mark or something, which has stung me, twice before.
The paper is a bit old though.In another surprise, they debunked the "bathtub model" of disk failure rates. In this theory, disks experience a higher "infant mortality" initial rate of failure, then settle down for a few years of low failure rate, and then begin to wear out and fail. The graph of the probability vs. time looks like a bathtub, flat in the middle and sloping up at the ends. Instead, the real-world failure rate began low and steadily increased over the years. Disks don't have a sweet spot of low failure rate.
Sometimes a sale is a good opportunity to take advantage of.I now have three qualified He10’s awaiting getting swapped in. I wonder if I should buy more given that they’re being sold for $79 a pop ATM….
As @diskdiddler illustrated, it is recommended to somehow burn-in drives before putting them "in production" in the NAS, but it is NOT specifically recommended to burn-in the drives in place, in the NAS; burn-in can be done in any other system, using any OS, any tool(s), and any procedure which suits the user.
If one uses a destructive procedure, such asbadblocks -w
