Building a Freenas box with AMD E-350
Wolfeman0101
AMD E-350 a good CPU for a Freenas 8 ZFS setup?
Here is my planned build:
ASUS E35M1-M PRO Fusion AMD E-350 APU (1.6GHz, Dual-Core) AMD Hudson M1 Micro ATX Motherboard/CPU Combo
(2) Seagate Barracuda Green ST2000DL003 2TB 5900 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(2) Western Digital Caviar Black WD1501FASS 1.5TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive (Plan to upgrade to 2TB 6.0Gb/s later)
ADATA Value-Driven S102 Pro Effortless Upgrade 16GB USB 3.0 Flash Drive (Gray) Model AS102P-16G-RG (Boot drive)
Intel EXPI9301CTBLK 10/ 100/ 1000Mbps PCI-Express Network Adapter
Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model KVR1066D3N7K2/8G
Thermaltake TR2 Series TR-450P 450W ATX 12V V2.3 & EPS 12V 2.91 80 PLUS BRONZE Certified Active PFC Power Supply
SilverStone SST-PS07B Black Steel / Plastic with Aluminum Accent MicroATX Mini Tower Computer Case
Thanks!
Joshua Parker Ruehlig
I use e-350 and have no complaints. If you haven't already bought the ram grab 2x8GB. I think it's will be a worthy upgrade.
frosted
You can't.
The ASUS E35M1-M PRO board doesn't support 8GB module, maximum is 4GB. 2x4GB is the maximum possible memory for this board.
From the manual:
You may install 512MB, 1GB, 2GB, AND 4GB unbuffered non-ECC DDR3 DIMMs into the DIMM sockets.
paleoN
Or can you?
Well it's working, I have tested 16GB ram on 2 different e-350 motherboards and both have worked. Guess I defied the specs Asus blindly put on their site, lol
YMMV.
I've personally tested 2 different brands of 2x8GB DDR3 ram on this motherboard and both worked flawlessly. The ASUS information for this motherboard is incorrect, it supports 2x8GB.
frosted
Can you confirm that the motherboard + OS really recognize 16GB memory?
It's one thing to be able to use 2x8GB module, but another to have the system/OS recognize the full 16GB.
Thanks in advance for the confirmation!
Wolfeman0101
Yes I 2nd this.
I also confirm OS see's it.
Mark09
Hi.
Could you please tell us which RAM brand/model you tested for 16GB?
Thanks
