Hi All,
I am planning to build new NAS device, bellow is the full components list. I would really appreciate if you comment on possible hardware that may not be compatible with the latest 8.0.2 version of freeNAS.
Actually any kind of comments are welcome.
Looking forward to hear what you think.
Thank you
SATA CARD: LSI Internal SATA/SAS 9211-8i 6Gb/s PCI-Express 2.0 RAID Controller Card, Single CABLES :2X HighPoint Int-MS-1M4S SFF-8087 to 4 SATA Fan Out Cable SSD : OCZ Onyx Series OCZSSD2-1ONX32G 2.5" 32GB SATA II MLC Internal Solid State Drive (SSD) HDD :10X Seagate Barracuda Green ST2000DL003 2TB 5900 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive CONVERTER: 2X StarTech 6" 4 Pin Molex to SATA Power Cable Adapter SATAPOWADAP MB : ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard CPU : Intel Xeon W3520 Bloomfield 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Server Processor BX80601W3520 CPU FAN : ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED RAM : G.SKILL PI Series 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T2-12GBPI CASE : Fractal Design Define XL Titanium Grey w/ USB 3.0 ATX Full Tower Silent PC Computer Case CASE FAN : NZXT FN-140RB 140mm Case Fan CASE FAN : Scythe SY1225SL12M 120mm "Slipstream" Case Fan PSU : COOLER MASTER Silent Pro Gold Series RSC00-80GAD3-US 1200W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply LAN : Intel EXPI9402PTBLK Two Gigabit Copper Server Connections 10/ 100/ 1000Mbps PCI-Express 2 x RJ45 - OEM CABLES : 2X CABLES TO GO 20088 50ft Cat5E 350 MHz Snagless Patch Cable - Red
Thank you
