input on my freenas build
jdratlif
Case - Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Power Supply - Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
Motherboard - BIOSTAR TA75M FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138333
CPU - AMD A4-3400 Llano 2.7GHz Socket FM1 65W Dual-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 6410D AD3400OJHXBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106014
RAM - G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9D-8GAB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550
HDD - 3x Western Digital WD AV-GP WD20EURS 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136783
MemStick - Patriot Xporter Mini 8GB Flash Drive (USB2.0 Portable) Model PSF8GMUSB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220301
Does anyone see any problems with this? I've heard FreeBSD doesn't like the AMD APUs, but I'm not using accelerated graphics for a NAS, so I think it won't matter.
Would it benefit me to add an Intel Gigabit Ethernet card rather than use the built-in RealTek 8111e?
Stephens
It looks fine, but it's difficult for people to give you input on whether the build is OK if they don't know what you plan to do with it. What will be stored on it? Multimedia? ATM transactions? How many devices will access it? Are they gigabit? Are you trying to do JBOD, RAID0, RAID1, RAID-Z1, RAID-Z2? In other words, do you want protection against HDD crashes? The more detail you provide, the better the feedback you'll get.
jdratlif
Sorry, that would be helpful.
I have a desktop and a laptop. They're both gigabit, thought I don't use the laptop much. I also have a couple TiVos. They have 100 Mbps interfaces, but will not interface directly with the FreeNAS box. They connect to the desktop via a program that transcodes and serves video over the network.
I mostly want a single place to keep all my files (video primarily). I switch between Linux, Windows, and OS X, and it's difficult to share data between them. Up till now, I've been keeping them on various partitions of various drives and copying data when I need to, often from external flash drives and hard drives.
Although I don't worry too much about disk failures, I have had huge file loses at times. I was planning to use RAIDZ1.
Stephens
I see no problems with your intended build given your stated uses. Make sure "4TB" is really going to be enough for what you want to store. If you plan on "growing" the pool later, I suggest reading up on some of the threads where that's discussed and reading noobsauce80's ZFS primer if you haven't already.
jdratlif
Do you have a link to that ZFS primer? I tried searching for it, but I didn't find it. I would like to read up on it.
Stephens
