I'm confused about what things need to work together for ECC memory. From the searching I've done, it seems like AMD is fairly good with ECC memory in their AM3/AM3+ socket CPUs, and Asus seems to have good ECC support.
So, here is the build I am considering.
ASUS M5A97 LE R2.0 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
AMD Sempron 145 Sargas - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103888
2x AMD Radeon 8GB DDR3 1600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820403019
4x WD NAS 2TB HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236343
Rosewill Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Rosewill 450W 80+GOLD Power - http://www.newegg.com/Product/Product.aspx?Item=N82E16817182066
Radeon HD 5450 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
16 GB ECC RAM for a RAIDZ2 Setup. I might buy a 5th drive for a hot spare.
Thoughts?
Thoughts?
