Well, ASRock has been extremely responsive and has already make a new BMC firmware fixing the voltage threshold. So at least, the hundreds of events in the log have stopped.. .
I have the same issue... After searching I found this on a forum :The board (c226 model) is reporting 1.7V vcore which is extremely high voltage with my Core i3. I already updated BMC and board firmware to newest and still getting 1.7V. Is anyone still having this issue? I will contact the asrock support but i will here first.
Hello all! I 'm intersted in buying the E3C224-4L motherboard, but I am a bit confused with its SATA Hot Plug/Swap support. In the product's webpage it is mentioned that there is Hot Plug support only for the ports offered by the Marvell SATA controller, but what about the ones offered by the C224 chipset? I couldn't figure this out by reading the manual either (while this is pretty clear with the C226M WS). I would like to use this feature with a 2U chassis that has a Hot Plug backplane (Norco RPC-2304).
I am also a bit confused about the PCIe speeds achieved when multiple cards are installed (eg, two GPU cards).
I would appreciate any help with the above questions. Thank you!
