Announcing FreeNAS 9.2.1.5 - waking up edition
So... apparently the whole "update the checksum properly when updating the download link" still can't be done right.. /sigh
J
jpaetzel
Guest
It wouldn't be FreeNAS if there wasn't a bug.
I'm attaching a shell script to run that fixes the issue where you can't stop CIFS unless you have the directory services set to domain controller.
put the script in /tmp then do as root:
sh /tmp/fixup.sh.txt
https://bugs.freenas.org/issues/4874
  • fixup.sh.txt
Savell Martin
Thanks for all the hard work guys...
I really dont mind if you keep releasing versions, as long as things get fixed!
So keep it up!
Sir.Robin
Patched applied and bug is confirmed fixed :)
J
jkh
Guest
Well, we can upload the bits to download.freenas.org. We can't update the freenas.org web site, however. Different department. It is what it is. :)
MartyB
Hi jkh,
Rather glad for the alternative downlink provided in this post as all the 86 check sums from the download page is incorrect.
Thank you.
mircsicz
thx panz,
I've renamed the pool by:
zpool export RAIDZ2
and than reimporting it in the WebGUI...
And fixed the AFPD "ad_header_read (): malformed AppleDouble" Prob by running:
find . -name '._*' -exec rm '{}' ';'
as mentioned by labtopia
Nick2253
Why not rerelease 9.2.1.5 with the fix for those who will update in the future?
Or just give us 9.2.1.6. I don't see what the problem is if you end up releasing a bunch of sub versions.
warri
Always bad to have the exact same version numbers with different content.. We still get 1-2 people a week complaining about broken updates with v9.2.1.2 (which was re-rolled under the same version because of this bug). Then you have to explain that there are actually two 9.2.1.2 images out there etc.
xcom
Team,
I try to do a fresh USB install of FreeNAS-9.2.1.5-RELEASE-x64.img.xz
Every time I tried the system was unable to mount the root filesystem when going through the boot up process... It will drop me to a prompt...
On the same usb disk FreeNAS-9.2.1.2-RELEASE-x64.img.xz works just fine.
Just reporting...
Regards,
X
Kevin Van
I have a weird issue trying to GUI update from 9.2.1.3 to 9.2.1.5.
The temporary .freenas directory gets an FTP user's name a group!
drwxrwxrwx 7 allen allen 8 Apr 25 13:44 .freenas
That user has no login and it chowned into a ZFS dataset. /mnt/storage/allen
There is nothing special about this user, no privs or anything, but was the first FTP user setup (UID 1002)
I poked around trying to see how this is happening and nothing obvious seen. I was thinking some part of the nginx/freenas install somehow became chown'd or ??
So, I go in as root and try chown root:wheel to .freenas and go into it and do rm -R * to clear it out and try again.
It gets set back to allen:allen on GUI upgrade. I also tried as a memory instead of /mnt/storage (root of the FTP).
Any ideas?
