BHyve isn't supported in FreeBSD 9.x, which is what FreeNAS 9.x is based on. The VMs / BHyve oriented GUI will come along in FreeNAS 10.@jkh - I like virtual box jail ! Any plans of making a new menu called "VMs" besides "Jails" and integrating that GUI with BHyVe ?
From the documentation: 'FreeNAS® provides an Alert icon in the upper right corner to provide a visual indication of events that warrant administrative attention. The alert system automatically emails the root user account whenever an alert is issued. ' So yes.Another question ... is there a current reporting email being sent when users exceed 80% zvol size ?
The warning email is at 95% which coincides with the change in ZFS behavior with regards to pool writes. It used to be 80% and anyone still saying 80% hasn't been updated with the changes to ZFS in the past 2 years. :p
Wait what's this ... NEWS to me! So ... does that mean the pool doesn't get "auto" corrupt when it reaches 100% anymore ?
The pool can still be corrupted at 100%. But the write behavior of ZFS changes at 95% from optimal write to maximize disk space utilization. One gives great write performance while one maximizes ZFS' use of space.
If you get to 100% you can still kill your pool because of an improper transaction. I don't think there's much chance of that changing anytime soon since you shouldn't be letting a pool get to 95% full anyway. Most ZFS guys i've chatted with consider corruption at 100% to be admin failure and is "deserved" because you failed to do your job.
Well, you set a quota of 95% and you create new problems because you make the pool unwriteable and requires work to restore it. You're just trading one problem for another.
You don't have to monitor it like a hawk, that's why it emails you when you get to 95% full. ;) You get the email, you order more disks and expand your pool(or delete stuff you don't need).
you know what would be nice ? having a "ZFS" quota and then having an option to have some kind of "CIFS" quota that is 3 percent smaller or whatever than the ZFS one ... then basically have cifs reject writing new data but have the actual file system have the ability to delete files still... not sure if that makes sense or not .... i mean ... lets say i make a new dataset for 1 user, and then he goes and fills up that dataset like a retard ... Can i really control him ? no ... will i get an e-mail alert ? no, because it's not the whole pool that is getting full, just that dataset that has the quota ...
On 9.2.1.3 they go out starting at 90% and multiple times after that until it is full.The warning email is at 95% which coincides with the change in ZFS behavior with regards to pool writes. It used to be 80% and anyone still saying 80% hasn't been updated with the changes to ZFS in the past 2 years. :P
The capacity for the volume 'scratch' is currently at 90%, while the recommended value is below 80%.
That is the best way to reserve space for the filesystem on the pool. And then you wont mess with your datasets containing all your data.ok, I don't want to hijack this thread, but why not use the reserved space option on a empty volume. in my testsetup this worked (could free up space and the other test volume was writeabel again)
I'm guessing nobody commented because no one else can reproduce it. If you select http+https in settings, then go to https://..., you will get the usual certificate warning from your browser (since the cert is self-signed, given no other action on your part to use a proper one), and it will happily use https or http. I just verified it with 9.2.1.6-BETA - works just fine.So going back to the beta ... nobody commented on my post regarding new versions of freenas ( don't know when that started ) not being able to enable HTTPS, every time i get warning that there is problem with certificate and it reverts back to HTTP.
I might suggest that the problem is with your browser, not FreeNAS. You probably have your security settings set such that any attempt to visit a site with a self-signed cert simply kicks you out and tries the non-SSL URL.
Nope, can't reproduce that at all. Did you try to upload your own certificate, perhaps? If the cert you tried to use was malformed or in some way invalid, that would account for this too. If you did this at some point in the distant past, it would also be getting pulled forward with your upgrades. I would check!No, i'm not getting the warning in the browser, i'm getting the warning in the same alerts area inside freenas ( where you usually see the ZFS volume status = healthy )
