Announcing FreeNAS-8.0.1-RC1
Dutchy
Hi everyone, I'm new!
I have recently made a FreeNAS box and freshly installed RC1 on it (coming from beta 4).
Has there something been changed about datasets?
I can't seem to create nested (children) datasets.
I cleanly installed RC1 (didn't do the upgrade).
Then I deleted the ZFS Volume and I created a new one.
Now I can only create datasets at the volume level and not in other datasets?
I believe this was possible with beta 4.
Is this a bug or is it by design?
enemy85
Do you get a sequence of ######## ?
In any event, it is most likely a BIOS incompatibility issue. There is a bug # opened with this issue (I am too lazy to search for it). I don't think it has been resolved. It usually happens with older PCs. Any chance you could update to a more modern BIOS?
i have the same problem of chris8051...
I have an AMD E350... with the 8.0.1 beta2 it worked, now with the RC1 it started at the beginnig but after at the reboot it goes in a continous loop...
Dutchy
Whoops, I seem to be confused with shares. It wasn't possible with previous versions.
There however is a post on the forum where they create these by CLI.
Ah well, never mind.
chris8051
I never got the betas to work but it does work with 0.7.2. FYI I am using Intel(R) Xeon(R) CPU E5630 @ 2.53GHz
andymemo
Im also on an AMD E350 architecture and had the reboot loop problem also from BETA3 onwards, see:
http://forums.freenas.org/showthread.php?695-FreeNAS-8.0.1-BETA3&p=4347#post4347
http://forums.freenas.org/showthread.php?1021-FreeNAS-8.0.1-BETA4&p=4541#post4541
Basically, turn off USB3 in your BIOS and you should be good :)
enemy85
enemy85
my mobo doesn't have any usb 3 port that's why i can't find that option
chris8051
Still no luck getting RC1 to boot on Dell PE R710
Currently running 0.7.2 Sabanda (revision 7529) on Dell PE R710.
(amd64-full on Intel(R) Xeon(R) CPU E5630 @ 2.53GHz)
I have it booting from hard disk. No problem works fine. But I have been unable to get RC1 to work on this same hardware fails during boot process (off USB Flash) seems like in endless loop. I have tried wiping the hard drive clean prior to the 8 install to make sure no residual info that might be confusing new install/boot.
None of the betas of 8 seem to work on this hardware. No USB3 settings on this device, and firmware is up to date (3.0)
M
Milos Vucekovic
Guest
Hello, im having problems with booting the 8.01 RC1, it says it cant mount FreeNASs1 and ask for bash path... 8.0 works just fine on the same hardware, hope the 8.01 final will work :)
Brad Bowers
So, previously I've upgraded my setup via the GUI... If I don't have physical access to an 8.01-Beta2 box to do the CD upgrade to RC1, is there any other way I might be able to go about getting this upgraded? I have access to the GUI and SSH... no other way to get to it for a long time really...
benool
You do have a 2+ Gb USB key to install FreeNAS8 on, right?
Since BETA4, the minimum size for install is 2gb.
benool
I'd stay away from RC1 for the moment. There seem to be quite a few issues being reported.
Similar threads
J
Replies
42
Views
33K
Joshua Parker Ruehlig
J
J
Replies
20
Views
20K
