I don't care too much about the nightly emails so I'll probably just wait for the official fix, but for now if you must receive the emails, edit the "daily_output" variable in /etc/defaults/periodic.conf and /conf/base/etc/defaults/periodic.conf to have your fully qualified email address and you should be back in business.
Hah, I didn't even try it myself. I guess I should :D. It seemed obvious that that would be the fix, but I guess I was wrong!Did anyone else try Durks fix for email? I tried it and got the same error/no email reports. (Changed BOTH files/locations)
# vi /etc/defaults/periodic.conf # cat /etc/defaults/periodic.conf | grep daily_output= daily_output="myusername@myemaildomain.com" # user or /file # /usr/sbin/periodic daily #
EDIT: OK, I *did* just try it and it worked. As root:
Code:# vi /etc/defaults/periodic.conf # cat /etc/defaults/periodic.conf | grep daily_output= daily_output="myusername@myemaildomain.com" # user or /file # /usr/sbin/periodic daily #
Now wait a few minutes for the periodic script to finish and then you should get an email provided you didn't fat-finger the email address in the conf file. It worked perfectly on my end just now!
Note that the each type of run has it's own setting: "weekly_output", "montlhy_output", "daily_status_security_output".
Same root cause as the daily emails gone missing, which as you noted is a known issue. There's a fix for that already ported into the 8.0.1 Subversion branch. I think the plan is to come out with a maintenance release of 8.0.1. If you can't wait, protosd has compiled up a build from source. You can try sending him a PM for the location.
I'll look at this this weekend. This might affect customers.
