I don't agree. The RM4024 has these fans
http://www.chenghome.com.tw/exec/product.php?mod=show&cid=9&pid=CHD12012&lg=E
here some good photos
http://hardforum.com/showthread.php?t=1745790&page=2
A friend of mine has the Supermicro SC846BA-R920B: it is damn loud and my hard drives run 2° C hotter in his case than in mine.
I live in the South Mediterranean and temperatures and humidity here reach high levels. I tested the RM 424 in a small closet with 4 KW vented heating pushing hot air. Ambient temp was 38° C during a 9 days stress-test, with my hard disks (WD Red 3GB) running this test 24/7:
badblocks -svw -b 4096 -t 0xFF -t 0x00 -t 0xFF /dev/daX
HDs' temperature never reached 40° C. The daughterboard fan controller works well with Supermicro's BIOS, regulating the fan speed. They're not quiet, but not as loud as Supemicro's.
That proves nothing. The kind of pull you can get with an 80mm fan just can't be matched with a 120mm fan unless you start talking 100w/fan for cooling. This is strictly theoretical limitations with the physics with it. So your comparison has nothing to do with what I'm trying to explain. You can have "good" 120mm fans and "crappy" 80mm fans. But even the best 120mm fans can't compete against "good" 80mm fans. They can't.. period. The physics makes it impossible. That's why I feel confident in saying "There's a reason why the expensive case has 80mm fans and the cheap one has 120mm fans". They understand these physics.
Your drives might run 2C hotter because he's using fans with a different temperature curve. He may even have them set artificially lower RPM. So comparing 2 cases is apples to oranges. There's far more headroom to get more cooling from 80mm fans over 120mm fans.
See, since I've got a background in this kind of thing, it's easy to pick out who actually used good engineering skills in development of a product. So while you see 120mm and 80mm and have various opinions on them, I see their choices through an engineer's eyes. And I see "fail" written on cases that choose to throw 24 drives in a 4U case and then use 120mm fans.
Then, add the fact that mine were WD Green drives and imagine how much worse the problem would be with drives that use more power, or even 7200RPM drives. Can you say "nightmare"?
