Build advice for a FreeNAS box including transcoding
Jack Naisbett
Ah thanks. I may stick to mirrors if I can grow, and start with 2 drives as I can fund that sooner. I'm fine with loss of storage for redundancy, I'm a paranoid data hoarder and will also have lots of external backups on top of the mirror redundancy
Stux
Then just start with 2 disks. Each time you get a space warning, buy another two disks ;) at whatever size is the then sweet spot. (Currently 4TB).
Don't forget to burnin the disks.
Once you run out of Sata ports begin replacing smaller drives with bigger ones.
Jack Naisbett
Having finally won the discussion, modified build here. Am I right in ignoring the "compatibility" issue, as SuperMicro seems to list the board as supporting M.2? (the m.2 will be the boot drive)
CPU: Intel Xeon E3-1230 V5 3.4GHz Quad-Core Processor (£263.08 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£23.97 @ Ebuyer)
Motherboard: Supermicro MBD-X11SSH-F Micro ATX LGA1151 Motherboard (£234.00)
Memory: Crucial 16GB (1 x 16GB) DDR4-2133 Memory (£150.97 @ Scan.co.uk)
Storage: Western Digital Green 120GB M.2-2280 Solid State Drive (£54.29 @ Amazon UK)
Storage: Western Digital Red 4TB 3.5" 5400RPM Internal Hard Drive (£133.20 @ Aria PC)
Case: Fractal Design Node 804 MicroATX Mid Tower Case (£90.98 @ Amazon UK)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply (£77.76 @ Amazon UK)
Total: £1427.85
