SOLVED ZPOOL IMPORT FAIL
loh
Good morning, This is the first time I've been in this situation with my pool and I can't find a solution. I am on Truenas-13.0-U5.3. My pool has gone offline and since then I can't import it back into Truenas. I tried with the GUI and I got I/O and python errors. Here is the information I can give. Thanks for your help.
zpool import
pool: DATA
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
DATA ONLINE
raidz1-0 ONLINE
gptid/6a7380b0-0d8c-11ec-aa1f-08606e691d26 ONLINE
gptid/e26c5bd0-19a3-11e9-aa72-7085c2b0131c ONLINE
spare-2 ONLINE
gptid/e37f8645-19a3-11e9-aa72-7085c2b0131c ONLINE
gptid/172f542b-2149-11ed-b0a9-08606e691d26 ONLINE
spares
zpool import DATA
cannot import 'DATA': I/O error
Destroy and re-create the pool from
a backup source.
loh
I tried this command, but it doesn't work and I don't know how to find the disk(s) that are unavailable.
zpool import DATA -f -F -m -X
cannot import 'DATA': one or more devices is currently unavailable
loh
I tried with ZDB to find the latest TGX and import with it but I always have the same result.
Please help me.
How can I find out which disk(s) is causing the problem?
ZFS_DBGMSG(zdb) START:
spa.c:6109:spa_import(): spa_import: importing DATA
spa_misc.c:419:spa_load_note(): spa_load(DATA, config trusted): LOADING
vdev.c:161:vdev_dbgmsg(): disk vdev '/dev/gptid/6a7380b0-0d8c-11ec-aa1f-08606e691d26': best uberblock found for spa DATA. txg
spa_misc.c:419:spa_load_note(): spa_load(DATA, config untrusted): using uberblock with txg=28114827
spa.c:8382:spa_async_request(): spa=DATA async request task=2048
spa_misc.c:419:spa_load_note(): spa_load(DATA, config trusted): LOADED
spa.c:8382:spa_async_request(): spa=DATA async request task=32
ZFS_DBGMSG(zdb) END
zpool import -d /dev/gptid/6a7380b0-0d8c-11ec-aa1f-08606e691d26 -T 28114827 DATA
NugentS
Please read Forum Rules - conveniently placed at the top of every page
Whattteva
Post your hardware, how the disks are connected and the output of geom disk list in code tags.
loh
Thank you for your reply.
My hardware is:
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Motherboard ASUS P8z77-V
16 Go DDR3 no ECC
ada0 -> zpool JAIL vdev JAIL (1disk)
ada1 -> Truenas
ada2,3,4,5 -> zpool DATA vdev DATA (4disk)
geom disk list
Geom name: ada1
Providers:
1. Name: ada1
Mediasize: 64022175232 (60G)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r1w1e2
descr: C300-CTFDDAC064MAG
lunid: 500a075102fbfbce
ident: 00000000102602FBFBCE
rotationrate: 0
fwsectors: 63
fwheads: 16
Geom name: ada4
Providers:
1. Name: ada4
Mediasize: 4000787030016 (3.6T)
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
descr: WDC WD40EFZX-68AWUN0
lunid: 50014ee268f1e044
ident: WD-WXC2D90LRK2C
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada5
Providers:
1. Name: ada5
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
lunid: 50014ee268f0b15b
ident: WD-WXC2D90ADU5Z
rotationrate: 5400
fwsectors: 63
fwheads: 16
Geom name: ada0
Providers:
1. Name: ada0
Mediasize: 128035676160 (119G)
Sectorsize: 512
Mode: r2w2e5
descr: TS128GSSD370S
ident: C392365620
rotationrate: 0
fwsectors: 63
fwheads: 16
Geom name: ada2
Providers:
1. Name: ada2
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
descr: ST4000DM004-2CV104
lunid: 5000c500be0321c2
ident: WFN0NCZJ
rotationrate: 5425
fwsectors: 63
fwheads: 16
Geom name: ada3
Providers:
1. Name: ada3
Sectorsize: 512
Stripesize: 4096
Stripeoffset: 0
Mode: r0w0e0
lunid: 5000c500be032a17
ident: WFN0ND1N
rotationrate: 5425
fwsectors: 63
fwheads: 16
Davvo
Can you post the output of camcontrol devlist as well?
There seem to be missing drives.
loh
camcontrol devlist
<TS128GSSD370S N1114H> at scbus2 target 0 lun 0 (ada0,pass0)
<C300-CTFDDAC064MAG 0007> at scbus3 target 0 lun 0 (ada1,pass1)
<ST4000DM004-2CV104 0001> at scbus4 target 0 lun 0 (ada2,pass2)
<ST4000DM004-2CV104 0001> at scbus5 target 0 lun 0 (ada3,pass3)
<WDC WD40EFZX-68AWUN0 81.00A81> at scbus6 target 0 lun 0 (ada4,pass4)
<WDC WD40EFZX-68AWUN0 81.00A81> at scbus7 target 0 lun 0 (ada5,pass5)
<AHCI SGPIO Enclosure 2.00 0001> at scbus8 target 0 lun 0 (ses0,pass6)
loh
I attach the result of 'zdb -e DATA'.
zdb -e DATA
Davvo
Those drives are SMR, known to cause this kind of issues with ZFS. If you aren't able to mount the pool at least in read-only mode I'd say your data is lost.
loh
Thank you for your reply. Can you give me the read-only mount options you recommend please.
- Otherwise, if I clone the disk will that change anything?
- Otherwise i'm in RAIDZ1 with spare I can't do anything with it?
Davvo
Before any of that, I just noticed that the state of the pool in the first post is online.
Can you please post the output of zpool status DATA between [CODE][/CODE] tags?
loh
zpool status DATA
cannot open 'DATA': no such pool
Davvo
Running zpool import -F -n DATA will tell you if it's possible to forcefully (with potential data loss) recover the pool; zpool import -F -X DATA is the more extreme way of recovery in case the simple zpool import -F DATA doesn't work.
In order to import the pool in read-only mode, run zpool import -F -o readonly=on DATA; you can use the -X here as well.
Cloning drives won't help, because the system expects drive number (examples) aa1, aa2, and aa3 to be in the pool: swapping them will only result in the pool yelling at you.
You can't manually do anything with that spare before you succesfully import the pool.
If anyone else has a better understanding of the situation, please chime in; I would prepare to restore from backups.
P.S.: Did you try power cyclying the system, didn't you?
loh
Thank you for your comprehensive response.
Yes i have power cyclying the system.
returns nothing. Which would mean that the command worked. but, always returns ->.
zpool status DATA
Destroy and re-create the pool from a backup source.
And the same
with -X option
thank you for your investment. the data on this pool is very important for me
Davvo
Well... I don't have anything else to give you. The pool is missing one or more devices, so unless moved one or more I don't think this is recoverable. If you don't have a backup you could try a recovery service, but they are bloody expensive for ZFS.
Maybe more experienced users can help you more.
loh
Thank you very much for your time in responding to me. Do you have a name for the recovery service recommended to me? If anyone else has an idea, thanks in advance.
Davvo
The only thing that comes to my mind is the following:
loh
Thanks again.
Indeed this application is expensive.
If anyone has other ideas, thanks in advance.
HoneyBadger
actually does care
Administrator
Thanks again.
Have you attempted to import the pool at an older transaction group using the -T flag, as you mentioned in your third post? The latest txg is not valid, so working your way backwards may result in an older uberblock being usable.
Did you experience a power outage or component failure? SMR drives are known to cause problems, but the Seagate ones have more commonly shown up as slow performance versus the WD Red IDNF issue - but in extreme cases SMR drives can be marked as faulted due to long I/O times, and in a RAIDZ1 two drives faulting would take the pool offline.
