Hi, I'm using FreeNAS-11.3-U4 running on ASRock B250 Gaming K4 with Intel i3-7100, 4x 8GB DDR4-2666 with the following 2 zpools:
1) store1 (4x 10TB WD in raid-z1)
2) zpool21 (10x 3TB WD in raid-z2)
My ZFS replication task is store1/shares -> zpool21/shares, and I'm getting the same Fatal trap 12 about every hour (ranging from 30-min to 1.5hrs) into the replication task. FreeNAS will freeze and had to perform a reset to restart FreeNAS.
Is this a bug with ZFS replication? Thanks in advance.
Here is the first screenshot - current process is solthread
The second screenshot - process is zfs
