All,
This is what I'm running on this NAS I am trying to build from an old HP Pavilion p6630f.
HP Pavilion p6630f (Was originally running WIN7 ULTIMATE SP1)
Iona MB
· Manufacturer: MSI
· Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
· Chipset: Intel H57 Express
· Memory sockets: 4 x DDR3
· Front side bus speeds: 2.5 GT/s DMI
· Processor socket: LGA1156
Intel Rapid Storage Technology (through BIOS not configured/configured for RAID 5 with Parity)
Intel Core i3 550 processor
4 WD 2TB HDD's (NEW - 2WD Red, 2WD Green)
1000W ANTEC Power Supply
4GB SanDisk USB (for FreeNAS Software) (Wiped, Killed, Loaded)
FreeNAS 9.1.2.9 Release x64
I can get the system to boot from the USB. When it does, I am presented with 5 boot options and not the 7 I have seen in the video tutorials. Within a split second the system begins to boot FreeNAS software, so I can't select any of the 5 boot options. All looks well but system errors out with a fatal trap 12 error. A cursor is available to input command data. I tried. No help. I Reboot. Same error. Even if I manage to select one of the 5 options made available during the initial boot, the system still hangs with the fatal trap 12 error.
Have seen other fatal trap 12's in the forum, but I have not seen any that match mine.
See error below:
Mounting local file systems:.
kernel trap 12 with interrupts disabled
Fatal trap 12: page fault while in kernel mode
cpuid = 3; apic id = 05
fault virtual address = 0x60b148
fault code = supervisor read data, page not present
instruction pointer = 0x20: 0xffffffff8085c00c
stack pointer = 0x28: 0xffffff8000261a60
frame pointer = 0x28: 0xffffff8000261aa0
code segment = base 0x0, limit 0xfffff, type0x1b
= DPL0, pres 1, long 1, def32 0, gran 1
processor eflags = resume, IOPL = 0
current process = 11 (idle: cpu3)
[ thread pid 11 tid 100006 ]
Stopped at callout_tickstofirst + 0x10c: movl 0x10 (%rdx), %r12d
db>
So, I have enough power, 4 good hard disk drives, and a working processor. I have no reason to think the new RAM is bad.
Should I get a new motherboard? New usb memory stick? If a new motherboard will do the trick using what I already have, send me your recommendations based on my current hardware. Same for the memory stick. If you see something else that sends up a red flag, let me know so I can apply/find a fix or shop for another solution.
Thanks
Iona MB
· Manufacturer: MSI
- Operating speed: Up to 3.2 GHz
- Number of cores: 2
- Socket: 1156
- Bus speed: DMI (Direct Media Interface) - 2.5 GT/s
See error below:
db>
Thanks
