I've been doing a little light reading on ZFS, and the abilities of ZFS are pretty instense. In regards to data integrity, confidentiality, and availability (CIA), ZFS has those bases covered. This list may not be all-inclusive or elaborate, but here's the features of ZFS (according to my understanding):
- protection against data corruption
- support for high storage capacity
- data compression
- integrated filesystem/volume management
- snapshot
- copy-on-write
- continuous integry checking
- automatic repair
- RAID-Z
Relative to a home media server, many of these features are unnecessary. For example, continuous integrity checking and copy-on-write for a few TB of movies is a bit overkill. These features are much more relevant in an enterprise environment where data must meet CIA standards.
I've seen plenty of posts regarding builds for a home media/data server. If you look at these users' situation objectively, then the question isn't really "How can I build a FreeNAS for this purpose?", but instead "Is FreeNAS the appropriate build for this purpose?" Objectively speaking, I think the answer to that question would be "no." A solution that is much more likely to fit their budget while fullfilling their needs would probably be a simple pre-built NAS from Amazon that only requires a HDD and setting some permissions, or maybe an Amazon Fire stick (depending on how basic you want to get).
Perhaps I'm a bit off on my thinking. Eh?
- data compression
- snapshot
- copy-on-write
- automatic repair
- RAID-Z
