ZFS crashing when writing for too long on SSD
Davvo
What about with k3s stopped?
systemctl stop k3s.service
(it may well just restart itself though... it's designed to be unkillable).
nooblard
Where is your system dataset? On the boot pool?
I'd check the pod logs.
The system dataset containing the logs is on the boot pool.
It hasn't restarted for 5 minutes. I killed k3s :cool:
Or were you talking about the zfs pod in k3s crashing?
Almost 100% sure that's all about memory consumption (i.e. you don't have enough of it to run your containers and have the NAS do other work).
nooblard
I was talking about zfs pod in k3s crashing.
OK; and does ZFS still crash with the copy now?
No more heavy io wait BUT, I still got have an issue because the TrueNAS reporting has continued to crash for a few seconds, maybe it's just a coïncidence.
You might be right then. But I'm surprised it has manifested recently and not since the beginning (almost 6 months).
EDIT : I got 2 blanks
There may be an obvious explanation for that which I can't see from my external viewpoint, but it's likely to be something that changed... upgraded version of some component or the OS kernel which handles memory differently, for example.
nooblard
Well, shoot.
Still thanks for your time.
If I found the solution without changing components (which will certainly not happen), I'll give it.
I'll have a look, if I find something weird, I'll add a post reply.
