(The BackGround)
I built a NAS in late 2016 to act as a plex media server. This is the only function i need the machine to perform. When i built it i think the version of freeNAS was 9.3, it ran beautifully. It wasn't the fastest machine on the plane but it could support 5 or 6 simultaneous streams and the write speed was acceptable. The set up was and still is
(The Machine)
ASRock AM1H-ITX AM1 SATA 6Gb/s USB 3.0 HDMI Mini ITX AMD Motherboard
AMD Sempron 3850 Kabini Quad-Core 1.3 GHz Socket AM1 25W SD3850JAHMBOX Desktop Processor AMD Radeon HD 8280
2 X HyperX FURY 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model HX313C9FRK2/16
4 X WD Red 3TB NAS Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD30EFRX
Corsair CX Series, CX430M, 430 Watt (430W), Semi Modular Power Supply, 80+ Bronze Certified
the drives were running in Raid Z1.
(The Problem)
The machine has been shelved for over a year and i recently pulled it out to get it up and running again. I ran into some issues upgrading so i transferred the data to a few spare drives i have and started with a clean slate. I installed 11.1 and got my plex plugin up and running. This is where i ran into the issue, when trying to move the media back to the NAS the write speed is abysmal!!! I am on a mac and can't see what the exactly what it is but it took over 3 minutes to move a single 1Gb movie to the drives. Also when attempting to stream this single movie the load time is excessive, i haven't even tried more than one at this point.
-I am transferring everything over wifi. The Router is not the bottleneck.
(The Question)
1) Is there a simple tweak to speed the machine up?
2) Is the new version to much for my hardware?
3) Will upgrading my CPU increase the performance of my machine substantially? ( AMD Athlon X4 845 with AMD quiet cooler Quad-Core Socket FM2+ 65W AD845XACKASBX Desktop Processor)
Thanks in advance!
(The Machine)
(The Problem)
(The Question)
Thanks in advance!
