I noticed recently that my write speed on my FreeNAS is pretty poor, I am only getting 30-40MBps (MegaBytes) write speed.
I am measuring this directly on the box, logged in as root, using dd:
[root@nas] /mnt/WDvol/Backup2# dd if=/dev/zero of=10gbfile bs=1024k count=10000
10485760000 bytes transferred in 271.820490 secs (38576047 bytes/sec)
vs. 77MBps read:
[root@nas] /mnt/WDvol/Backup2# dd if=10gbfile of=/dev/null bs=1024k count=10000
10485760000 bytes transferred in 135.784284 secs (77223664 bytes/sec)
On a different Linux system with a SATA 2 disk I get
$ dd if=/dev/zero of=10gbfile bs=1024k count=10000
10485760000 bytes (10 GB, 9.8 GiB) copied, 118.19 s, 88.7 MB/s
(8GB RAM, ext4 (no RAID), 4 Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz)
But on FreeNAS then when I am reading directly from the raw disks, I am getting about 150MBps (MegaBytes)
[root@nas] ~# dd if=/dev/ada0 of=/dev/null bs=1024k count=10000
10485760000 bytes transferred in 69.976778 secs (149846282 bytes/sec)
I understand I am comparing apples and bananas here, but I would expect to have at least 80MBps write speed locally on FreeNAS.
Things I have tried to find the culprit:
are "0", then activity again - it keeps fluctuating. Whereas the throughput via network (rsync --stats --progress) is steady at about 30MBps).
What am I missing here? Is this normal?
Regards
Tom
Software and hardware specs
I have one RAIDZ1 pool spanning all 3 disks, no encryption, compression was enabled, but I disabled this now.
Compression rates were insignificant, like 1.06 was the best. Disabling compression didn't show any improvement.
FreeNAS-9.10.1 (d989edd)
AMD Turion(tm) II Neo N40L Dual-Core Processor, SATA 2 only
8130MB ECC RAM
3x2TB WD RED disks, SATA 3 (they support 4k or "Advanced Format")
vs. 77MBps read:
- No SMART errors, no disk errors whatsoever. Running a scrub regularily and no errors reported ever.
- diskinfo -v ada(0,1,2) reports a stripesize of 4096, so I guess I have used 4k sectors when formatting
- zdb -U /data/zfs/zpool.cache gives me ashift: 12
- Tried with zfs sync=disabled WDvol/Backup2 and then test again, no change
- I noticed this slowness with with CIFS, but also with SSH as well. Tested networkspeed with iperf and ifconfig and everything is 1Gbps, what I expect.
Regards
Tom
8130MB ECC RAM
