Hey community :),
I am quite new to FreeNAS but feel really comfortable with webUI and the easy configuration.
However, somehow I am experiencing a strange behaviour when trying to use Wake on LAN feature which is natively supported by both, the MB and the Onboard NI.
Before I dive into the problem itself, let me clear up some things:
- I know that my HW-specs do NOT follow the recommendations
- Yes, I also know that WoL is NOT recommended at all, as FreeNAs is supposed to run 24/7
*this is just for me being lazy, as I do not want to stand up and reach the pwr button in case I wanna use the NAS ;D
- I am not willing to invest in another NI until I am sure that I have tried everything possible
- Specs at the end of the Thread ;)
Thank you for your understanding :)
Now to the Problem:
FreeNAS is running perfectly fine either way: DHCP and with a static IP.
I can reach the webUI and the data with no Problems at all.
However, everytime I activate the WoL Feature of my MB/Onboard-LAN FreeNAs is not able to connect to my Network.
The behaviour differs depending on whether I configure a dynamic or a static IP.
(For completeness: within my Router I bound the MAC-Adress to a static IP when assigned one within freenas console)
on DHCP:
FreeNAs sends DHCPRECEIVE
Router gets the demand and sends a DHCPOFFER
FreeNAS gets nothing and retries
This cycle repeats until I get 'No DHCPOFFERS'.
NAS is started but with 'reach the UI via http://0.0.0.0'
on Static IP:
FreeNAS boots up and says:
'reach UI via http://[ASSIGNED STATIC IP]'
But I cant reach the frontend.
I can ping, but thats all.
From within my BIOS menu I can access the internet (more specific: the UEFI update server)
And: If the NAS is shut down I can start it via WoL.
So basically I have the 2 options:
WoL works, but NAS is not reachable
WoL deactivated and NAs is reachable.
And to add to my Problems...when i am able to reach the webUI i am not able top connect to ntp servers or the update server...
This is not really satisfying ;)
Following the logs per shell commands
dmesg:
ifconfig re0:
Static IP
DHCP
ifconfig re0:
My Specs:
Router: Archer C7 (Hardware rev 2)
Network Access: via Win7 PC->Network Storage /FFX for webUI
FN Ver: FreeNAS 9.3.1 STABLE
MB: ASRock AM1H-ITX
Onboard NI: Realtek RTL8111GR ASIC
CPU: AMD Athlon 5350 Boxed
RAM: 2X 8GB Kingstom ValueRAM DDR3-1600 DIMM
HDD: 4x 4TB WD Green WD40EZRX 64MB 3.5"
RAID: RAIDZ (RAID5)
NI Config (static)
IP 192.168.0.3
GW: 192.168.0.1
mask /24 (255.255.255.0)
Maybe useful Info:
- I just recently updated to 9.3.1 stable from 9.3.0, however did not experience issues or at least didnt feel any...
-The WOL works perfectly fine for my W7 Desktop PC
-Already tried restoring factory defaults
-Already removed the NI via command shell and cleared network configs etc.
-Even when the WebUI is reachable i cant seem to reach the FreeNAs update-servers (May be connected to arpresolve i guess).
-Even though I entered a namespace under the general tab for Network config, I cant seem to get ntp times
-My GF is not a friend of technical stuff, therefore it could be possible that I can only test new possible solutions on specific days ;D
Thank you all in dvance for your help.
Kind regards,
Stahler
EDIT:
A friend of mine is using the EXACT same HW Setup, for him everything seems to be working.
If it is the most easy way to reinstall freenas.
How am i able to do so without losing my datasets/data already on the NAS?
Now to the Problem:
on DHCP:
on Static IP:
dmesg:
Copyright (c) 1992-2014 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.3-RELEASE-p28 #0 r288272+f229c79: Sat Dec 12 11:58:01 PST 2015 root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd6 4 amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: AMD Athlon(tm) 5350 APU with Radeon(tm) R3 (2050.04-MHz K8-class CPU) Origin = "AuthenticAMD" Id = 0x700f01 Family = 0x16 Model = 0x0 Stepping = 1 Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT> Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C> AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM> AMD Features2=0x154037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PL2I> Standard Extended Features=0x8 TSC: P-state invariant, performance statistics real memory = 18236833792 (17392 MB) avail memory = 15912804352 (15175 MB) Event timer "LAPIC" quality 400 ACPI APIC Table: <ALASKA A M I> FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs FreeBSD/SMP: 1 package(s) x 4 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ACPI Warning: FADT (revision 5) is longer than ACPI 5.0 version, truncating length 268 to 256 (20111123/tbfadt-325) ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20111123/tbfadt-606) ioapic0 <Version 2.1> irqs 0-23 on motherboard ioapic1 <Version 2.1> irqs 24-55 on motherboard ispfw: registered firmware <isp_1040> ispfw: registered firmware <isp_1040_it> ispfw: registered firmware <isp_1080> ispfw: registered firmware <isp_1080_it> ispfw: registered firmware <isp_12160> ispfw: registered firmware <isp_12160_it> ispfw: registered firmware <isp_2100> ispfw: registered firmware <isp_2200> ispfw: registered firmware <isp_2300> ispfw: registered firmware <isp_2322> ispfw: registered firmware <isp_2400> ispfw: registered firmware <isp_2400_multi> ispfw: registered firmware <isp_2500> ispfw: registered firmware <isp_2500_multi> kbd1 at kbdmux0 cryptosoft0: <software crypto> on motherboard aesni0: <AES-CBC,AES-XTS> on motherboard padlock0: No ACE support. acpi0: <ALASKA A M I> on motherboard acpi0: Power Button (fixed) cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 Event timer "RTC" frequency 32768 Hz quality 0 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 950 Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 vgapci0: <VGA-compatible display> port 0xf000-0xf0ff mem 0xc0000000-0xcfffffff,0xd0000000-0xd07fffff,0xffb00000-0xffb3ffff irq 44 at device 1.0 on pci0 vgapci0: Boot video device pci0: <multimedia, HDA> at device 1.1 (no driver attached) pcib1: <ACPI PCI-PCI bridge> irq 25 at device 2.2 on pci0 pci1: <ACPI PCI bus> on pcib1 ahci0: <ASMedia ASM1061 AHCI SATA controller> port 0xe050-0xe057,0xe040-0xe043,0xe030-0xe037,0xe020-0xe023,0xe000-0xe01f mem 0xffa00 000-0xffa001ff irq 28 at device 0.0 on pci1 ahci0: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 pcib2: <ACPI PCI-PCI bridge> irq 26 at device 2.3 on pci0 pci2: <ACPI PCI bus> on pcib2 re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem 0xff900000-0xff900fff,0xd0800000-0xd0803fff irq 32 at device 0.0 on pci2 re0: Using 1 MSI-X message re0: Chip rev. 0x4c000000 re0: MAC rev. 0x00000000 miibus0: <MII bus> on re0 rgephy0: <RTL8251 1000BASE-T media interface> PHY 1 on miibus0 rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-m aster, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow re0: Ethernet address: d0:50:99:61:61:67 pcib3: <ACPI PCI-PCI bridge> irq 27 at device 2.4 on pci0 pci3: <ACPI PCI bus> on pcib3 pci3: <serial bus, USB> at device 0.0 (no driver attached) pci0: <serial bus, USB> at device 16.0 (no driver attached) ahci1: <AMD Hudson-2 AHCI SATA controller> port 0xf140-0xf147,0xf130-0xf133,0xf120-0xf127,0xf110-0xf113,0xf100-0xf10f mem 0xffb6e000 -0xffb6e3ff irq 19 at device 17.0 on pci0 ahci1: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported ahcich2: <AHCI channel> at channel 0 on ahci1 ahcich3: <AHCI channel> at channel 1 on ahci1 ohci0: <OHCI (generic) USB controller> mem 0xffb6d000-0xffb6dfff irq 18 at device 18.0 on pci0 usbus0 on ohci0 ehci0: <EHCI (generic) USB 2.0 controller> mem 0xffb6c000-0xffb6c0ff irq 17 at device 18.2 on pci0 usbus1: EHCI version 1.0 usbus1 on ehci0 ohci1: <OHCI (generic) USB controller> mem 0xffb6b000-0xffb6bfff irq 18 at device 19.0 on pci0 usbus2 on ohci1 ehci1: <EHCI (generic) USB 2.0 controller> mem 0xffb6a000-0xffb6a0ff irq 17 at device 19.2 on pci0 usbus3: EHCI version 1.0 usbus3 on ehci1 pci0: <multimedia, HDA> at device 20.2 (no driver attached) isab0: <PCI-ISA bridge> at device 20.3 on pci0 isa0: <ISA bus> on isab0 amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb5 acpi_button0: <Power Button> on acpi0 uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 orm0: <ISA Option ROM> at iomem 0xcf000-0xd6fff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this. hwpstate0: <Cool`n'Quiet 2.0> on cpu0 ZFS filesystem version: 5 ZFS storage pool version: features support (5000) Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled usbus0: 12Mbps Full Speed USB v1.0 usbus1: 480Mbps High Speed USB v2.0 usbus2: 12Mbps Full Speed USB v1.0 usbus3: 480Mbps High Speed USB v2.0 ugen0.1: <AMD> at usbus0 uhub0: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 ugen1.1: <AMD> at usbus1 uhub1: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 ugen2.1: <AMD> at usbus2 uhub2: <AMD OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2 ugen3.1: <AMD> at usbus3 uhub3: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3 uhub0: 4 ports with 4 removable, self powered uhub2: 4 ports with 4 removable, self powered uhub1: 4 ports with 4 removable, self powered uhub3: 4 ports with 4 removable, self powered ugen3.2: <SanDisk> at usbus3 umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.27, addr 2> on usbus3 umass0: SCSI over Bulk-Only; quirks = 0x8100 umass0:5:0:-1: Attached to scbus5 ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 ada0: <WDC WD40EZRX-22SPEB0 80.00A80> ATA-9da0 at umass-sim0 bus 0 scbus5 target 0 lun 0 da0: <SanDisk Cruzer Fit 1.27> Removable Direct Access SCSI-6 device da0: Serial Number 4C530102800317100525 da0: 40.000MB/s transfers da0: 15267MB (31266816 512 byte sectors: 255H 63S/T 1946C) da0: quirks=0x2<NO_6_BYTE> SATA 3.x device ada0: Serial Number WD-WCC4E1YZD01U ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C) ada0: quirks=0x1<4K> ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 ada1: <WDC WD40EZRX-22SPEB0 80.00A80> ATA-9 SATA 3.x device ada1: Serial Number WD-WCC4E0NUJCX3 ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C) ada1: quirks=0x1<4K> ada1: Previously was known as ad6 ada2 at ahcich2 bus 0 scbus2 target 0 lun 0 ada2: <WDC WD40EZRX-22SPEB0 80.00A80> ATA-9 SATA 3.x device ada2: Serial Number WD-WCC4E4DH1JES ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C) ada2: quirks=0x1<4K> ada2: Previously was known as ad8 ada3 at ahcich3 bus 0 scbus3 target 0 lun 0 ada3: <WDC WD40EZRX-22SPEB0 80.00A80> ATA-9 SATA 3.x device ada3: Serial Number WD-WCC4E0NUJK11 ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C) ada3: quirks=0x1<4K> ada3: Previously was known as ad10 SMP: AP CPU #1 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #2 Launched! Timecounter "TSC" frequency 2050039122 Hz quality 1000 Trying to mount root from zfs:freenas-boot/ROOT/FreeNAS-9.3-STABLE-201512121950 []... GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this. GEOM_ELI: Device ada0p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device ada1p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device ada2p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device ada3p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware vboxdrv: fAsync=0 offMin=0x2af offMax=0x8b5a arpresolve: can't allocate llinfo for 192.168.0.1 (^ this repeats like 50 times) pid 1624 (syslog-ng), uid 0: exited on signal 6 (core dumped) arpresolve: can't allocate llinfo for 192.168.0.1 (^again, repeats for like 150 times)
ifconfig re0:
Static IP
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether d0:50:99:61:61:67 inet 192.168.0.3 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex,master>) status: active
DHCP
ifconfig re0:
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE> ether d0:50:99:61:61:67 inet 192.168.0.101 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex,master>) status: active
My Specs:
MB: ASRock AM1H-ITX
RAID: RAIDZ (RAID5)
NI Config (static)
IP 192.168.0.3
GW: 192.168.0.1
Maybe useful Info:
Kind regards,
Stahler
EDIT:
