Performance issue
realdreams
My FreeNAS box:
AMD*Athlon*X4 2.2GHz
7G DDR2
3* 1TB SATA2 HDD, zfs, stripe
Intel PRO/1000 PT Dual Port Server Adapter (iSCSI)
Realtek PCI-E GbLAN 8111DL (management, iSCSI and CIFS)
It works ok for light use. I get 40MB/s max for CIFS or iSCSI.
Intel PRO/1000 PT connected to an ESXi 5.1 server, software iSCSI HBA, round-robin. Intel PRO/1000 PT Dual Port Server Adapter.
Cloning takes forever.... It is a lot slower than a SMB iSCSI SAN I used before. I noticed latency spikes as i/o requests increase. It can easily go above 20ms under load, to like 300ms
I expect the performance to be a lot better than 40MB/s in 3 disk stripe... Where should I begin to troubleshoot? Thanks
[root@freenas] /mnt/volume_test# dd if=/dev/zero of=/mnt/volume_test/ddtest bs=2048k count=10000
10000+0 records in
10000+0 records out
20971520000 bytes transferred in 22.224931 secs (943603379 bytes/sec)
[root@freenas] /mnt/volume_test# dd of=/dev/zero if=/mnt/volume_test/ddtest bs=2048k count=10000
10000+0 records in
10000+0 records out
20971520000 bytes transferred in 18.848734 secs (1112622212 bytes/sec)
[root@freenas] /mnt/volume_test# dmesg
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p9 #0: Thu Jul 19 12:39:10 PDT 2012
root@build.ixsystems.com:/build/home/jpaetzel/8.2.0/os-base/amd64/build/home/jpaetzel/8.2.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Phenom(tm) FX-5000 Quad-Core Processor (2200.10-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x100f42 Family = 10 Model = 4 Stepping = 2
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x802009<SSE3,MON,CX16,POPCNT>
AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x37ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT>
TSC: P-state invariant
real memory = 7516192768 (7168 MB)
avail memory = 7183179776 (6850 MB)
ACPI APIC Table: <7551MS A7551800>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20101013/tbfadt-655)
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <MSI_NB MEGABOOK> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, dfe00000 (3) failed
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xc000-0xc0ff mem 0xfa000000-0xfbffffff,0xfe8f0000-0xfe8fffff,0xfe700000-0xfe7fffff irq 18 at device 5.0 on pci1
pci1: <multimedia, HDA> at device 5.1 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib2
em0: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0xd800-0xd81f mem 0xfe9e0000-0xfe9fffff,0xfe9c0000-0xfe9dffff irq 18 at device 0.0 on pci2
em0: Using an MSI interrupt
em0: [FILTER]
em0: Ethernet address: 00:15:17:5b:8d:48
em1: <Intel(R) PRO/1000 Network Connection 7.1.9> port 0xd400-0xd41f mem 0xfe9a0000-0xfe9bffff,0xfe980000-0xfe99ffff irq 19 at device 0.1 on pci2
em1: Using an MSI interrupt
em1: [FILTER]
em1: Ethernet address: 00:15:17:5b:8d:49
pcib3: <ACPI PCI-PCI bridge> irq 17 at device 5.0 on pci0
pci3: <ACPI PCI bus> on pcib3
re0: <RealTek 8168/8111 B/C/CP/D/DP/E PCIe Gigabit Ethernet> port 0xe800-0xe8ff mem 0xfdfff000-0xfdffffff,0xfdff8000-0xfdffbfff irq 17 at device 0.0 on pci3
re0: Using 1 MSI-X message
re0: Chip rev. 0x28000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: 40:61:86:be:7e:d2
re0: [ITHREAD]
ahci0: <ATI IXP700 AHCI SATA controller> port 0xb000-0xb007,0xa000-0xa003,0x9000-0x9007,0x8000-0x8003,0x7000-0x700f mem 0xfe6ffc00-0xfe6fffff irq 22 at device 17.0 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.10 with 6 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich5: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xfe6fe000-0xfe6fefff irq 16 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ohci1: <OHCI (generic) USB controller> mem 0xfe6fd000-0xfe6fdfff irq 16 at device 18.1 on pci0
ohci1: [ITHREAD]
usbus1: <OHCI (generic) USB controller> on ohci1
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe6ff800-0xfe6ff8ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus2: EHCI version 1.0
usbus2: <EHCI (generic) USB 2.0 controller> on ehci0
ohci2: <OHCI (generic) USB controller> mem 0xfe6fc000-0xfe6fcfff irq 18 at device 19.0 on pci0
ohci2: [ITHREAD]
usbus3: <OHCI (generic) USB controller> on ohci2
ohci3: <OHCI (generic) USB controller> mem 0xfe6f7000-0xfe6f7fff irq 18 at device 19.1 on pci0
ohci3: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci3
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe6ff400-0xfe6ff4ff irq 19 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus5: EHCI version 1.0
usbus5: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0
ata0: <ATA channel 0> on atapci0
ata0: [ITHREAD]
pci0: <multimedia, HDA> at device 20.2 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib4: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci4: <ACPI PCI bus> on pcib4
bge0: <HP NC7771 Gigabit Server Adapter, ASIC rev. 0x001100> mem 0xfebf0000-0xfebfffff irq 21 at device 6.0 on pci4
bge0: CHIP ID 0x00001100; ASIC REV 0x01; CHIP REV 0x11; PCI
miibus1: <MII bus> on bge0
brgphy0: <BCM5703 10/100/1000baseTX PHY> PHY 1 on miibus1
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: 00:08:02:91:b6:39
bge0: [ITHREAD]
ohci4: <OHCI (generic) USB controller> mem 0xfe6f6000-0xfe6f6fff irq 18 at device 20.5 on pci0
ohci4: [ITHREAD]
usbus6: <OHCI (generic) USB controller> on ohci4
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
acpi_hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
device_attach: acpi_hpet1 attach returned 12
orm0: <ISA Option ROM> at iomem 0xd0800-0xd47ff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
usbus6: 12Mbps Full Speed USB v1.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
uhub6: 2 ports with 2 removable, self powered
uhub0: 3 ports with 3 removable, self powered
uhub1: 3 ports with 3 removable, self powered
uhub3: 3 ports with 3 removable, self powered
uhub4: 3 ports with 3 removable, self powered
uhub2: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
ugen2.2: <SanDisk> at usbus2
umass0: <SanDisk U3 Cruzer Micro, class 0/0, rev 2.00/2.00, addr 2> on usbus2
ada0 at ahcich1 bus 0 scbus1 target 0 lun 0
ada0: <Hitachi HDS721010CLA332 JP4OA39C> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich2 bus 0 scbus2 target 0 lun 0
ada1: <ST31000528AS CC49> ATA-8 SATA 2.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)da0 at umass-sim0 bus 0 scbus7 target 0 lun 0
da0: <SanDisk U3 Cruzer Micro 8.02> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 3863MB (7913471 512 byte sectors: 255H 63S/T 492C)
ada1: Command Queueing enabled
ada1: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada2 at ahcich3 bus 0 scbus3 target 0 lun 0
ada2: <WDC WD10EADS-22M2B0 01.00A01> ATA-8 SATA 2.x device
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #1 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS filesystem version 4
ZFS storage pool version 15
