HELP, ZFS pool not found
LAYGO
My original install on an older thumbdrive crapped out, I luckily got it to boot 1 more time to get a config backup. The original install was 8.0.2-Release. I'm now on 8.0.3-Release-P1. I don't think that would cause the pool not to be found, but I couldn't find the archived versions to try from 8.0.2.
So, I had pulled my drives out while trying to see if I could get the system to boot because I didn't want to accidentally nuke the data or anything (still a noob to all this). Once I got it to actually boot, I restored the config, but didn't put in the drives, when it booted it said "pool not found". Ah, so I put the drives in, rebooted, still pool not found. Rebooted once more, reloaded the config, rebooted during the config, still pool not found. I tried auto import from the GUI, doesn't show anything. I'm almost afraid I should've exported before doing all this, but I'm not sure what the whole ZFS import/export process is. I'm learning as I'm going.
When I tried to search on "pool not found" using quotes, the forum thinks its "pool -found". :( Where does that log show where the pool is?
Copyright (c) 1992-2011 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.2-RELEASE-p6 #0: Wed Jan 18 13:52:11 PST 2012
    root@build.ixsystems.com:/build/home/gcooper/e2e-bld.Pp7kV0qa/obj.amd64/build/home/gcooper/e2e-bld.Pp7kV0qa/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: AMD Turion(tm) II Neo N40L Dual-Core Processor (1497.52-MHz K8-class CPU)
  Origin = "AuthenticAMD"  Id = 0x100f63  Family = 10  Model = 6  Stepping = 3
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x802009<SSE3,MON,CX16,POPCNT>
  AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
  AMD Features2=0x837ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,<b19>>
  TSC: P-state invariant
real memory  = 4294967296 (4096 MB)
avail memory = 3975692288 (3791 MB)
ACPI APIC Table: <HP     ProLiant>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  1
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
acpi0: <HP ProLiant> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed80000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, d7f00000 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xe000-0xe0ff mem 0xf0000000-0xf7ffffff,0xfe8f0000-0xfe8fffff,0xfe700000-0xfe7fffff irq 18 at device 5.0 on pci1
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 6.0 on pci0
pci2: <ACPI PCI bus> on pcib2
bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f0000-0xfe9fffff irq 18 at device 0.0 on pci2
bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5784 10/100/1000baseTX PHY> PHY 1 on miibus0
brgphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: 2c:76:8a:ad:f7:2c
bge0: [FILTER]
ahci0: <ATI IXP700 AHCI SATA controller> port 0xd000-0xd007,0xc000-0xc003,0xb000-0xb007,0xa000-0xa003,0x9000-0x900f mem 0xfe6ffc00-0xfe6fffff irq 19 at device 17.0 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.20 with 4 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich1: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich3: [ITHREAD]
ohci0: <OHCI (generic) USB controller> mem 0xfe6fe000-0xfe6fefff irq 18 at device 18.0 on pci0
ohci0: [ITHREAD]
usbus0: <OHCI (generic) USB controller> on ohci0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe6ff800-0xfe6ff8ff irq 17 at device 18.2 on pci0
ehci0: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci0
ohci1: <OHCI (generic) USB controller> mem 0xfe6fd000-0xfe6fdfff irq 18 at device 19.0 on pci0
ohci1: [ITHREAD]
usbus2: <OHCI (generic) USB controller> on ohci1
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe6ff400-0xfe6ff4ff irq 17 at device 19.2 on pci0
ehci1: [ITHREAD]
usbus3: EHCI version 1.0
usbus3: <EHCI (generic) USB 2.0 controller> on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
atapci0: <ATI IXP700/800 UDMA133 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xff00-0xff0f at device 20.1 on pci0
ata0: <ATA channel 0> on atapci0
ata0: [ITHREAD]
ata1: <ATA channel 1> on atapci0
ata1: [ITHREAD]
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib3: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci3: <ACPI PCI bus> on pcib3
ohci2: <OHCI (generic) USB controller> mem 0xfe6fc000-0xfe6fcfff irq 18 at device 22.0 on pci0
ohci2: [ITHREAD]
usbus4: <OHCI (generic) USB controller> on ohci2
ehci2: <EHCI (generic) USB 2.0 controller> mem 0xfe6ff000-0xfe6ff0ff irq 17 at device 22.2 on pci0
ehci2: [ITHREAD]
usbus5: EHCI version 1.0
usbus5: <EHCI (generic) USB 2.0 controller> on ehci2
amdtemp0: <AMD K8 Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
acpi_hpet1: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
device_attach: acpi_hpet1 attach returned 12
atkbd: unable to set the command byte.
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
psm0: unable to set the command byte.
ppc0: cannot reserve I/O port range
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 480Mbps High Speed USB v2.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus5
uhub4: 4 ports with 4 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub5: 4 ports with 4 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen3.2: <vendor 0x0781> at usbus3
umass0: <vendor 0x0781 Staples, class 0/0, rev 2.00/1.22, addr 2> on usbus3
ugen0.2: <vendor 0x0b38> at usbus0
ukbd0: <vendor 0x0b38 product 0x0010, class 0/0, rev 1.10/1.02, addr 2> on usbus0
kbd2 at ukbd0
uhid0: <vendor 0x0b38 product 0x0010, class 0/0, rev 1.10/1.02, addr 2> on usbus0
ada0 at ahcich2 bus 0 scbus2 target 0 lun 0
ada0: <Hitachi HDS723020BLA642 MN6OA180> ATA-8 SATA 3.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich3 bus 0 scbus3 target 0 lun 0
ada1: <Hitachi HDS722020ALA330 JKAOA3EA> ATA-8da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: <Staples  1.22> Removable Direct Access SCSI-5 device
da0: 40.000MB/s transfers
da0: 3819MB (7821312 512 byte sectors: 255H 63S/T 486C)
 SATA 2.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
SMP: AP CPU #1 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
            to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
ZFS filesystem version 4
ZFS storage pool version 15
bge0: link state changed to UP
[root@freenas] /var/log# df -h
Filesystem             Size    Used   Avail Capacity  Mounted on
/dev/ufs/FreeNASs1a    927M    375M    477M    44%    /
devfs                  1.0K    1.0K      0B   100%    /dev
/dev/md0               4.6M    1.8M    2.3M    44%    /etc
/dev/md1               824K    1.5K    757K     0%    /mnt
/dev/md2               149M    7.7M    130M     6%    /var
/dev/ufs/FreeNASs4      20M    577K     18M     3%    /data
[root@freenas] /var/log# zpool status
no pools available
ProtoSD
Try doing a "gpart show" and posting the results. Don't freak out and do anything yet, your pool is probably fine. Sometimes the device names change and the GUI/database thinks they're called something else and won't/can't import them. Post those results and me or someone here can help you figure out what's happening.
LAYGO
I should have a 6tb pool, RAIDZ1 (4x2tb).
[root@freenas] /var/log# gpart show
=>     63  7821198  da0  MBR  (3.7G)
       63  1930257    1  freebsd  [active]  (943M)
  1930320       63       - free -  (32K)
  1930383  1930257    2  freebsd  (943M)
  3860640     3024    3  freebsd  (1.5M)
  3863664    41328    4  freebsd  (20M)
  3904992  3916269       - free -  (1.9G)
=>      0  1930257  da0s1  BSD  (943M)
        0       16         - free -  (8.0K)
       16  1930241      1  !0  (943M)
=>        34  3907029101  ada0  GPT  (1.8T)
          34          94        - free -  (47K)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  3902834703     2  freebsd-zfs  (1.8T)
=>        34  3907029101  ada1  GPT  (1.8T)
LAYGO
So, am I screwed or what? I have no idea how to proceed w/o losing all of my data! :(
Wait a cotton picking moment. Really reading the dmesg, it's only picking up 2 of the 4 drives. WTF? This is a Proliant MicroServer N40L, so there's no cabling as it's a back plane & drives are in trays that slide in & latch. Nothing was wrong with my RAID when the thumb drive w/the OS on it crapped out. WTF?!?!? :(
LAYGO
So, checking the BIOS, it's showing drives 2 & 3, not 0 & 1. I swapped drives 1 & 3, still see drives 2 & 3. Might be something going on internally with the cabling. Will need to crack the case. :(
LAYGO
Do you not have a current backup of your data?
Of course I do . . . OFFSITE! I just don't have it here, but I'm thinking it's a bigger issue with the back plane seeing only 2 of the 4 drives. Dunno why.
LAYGO
P H E W !
I think it was just a loose cable, but I hadn't been able to open her up until now. Reseated all the power, all the drives, and the mobo's mini-sas, booted it, all 4 drives showed. I'm able to view the files as well. Need to reconfigure Transmission/Serviio again . . .
