I am having trouble getting a previously created USB3
hard drive to be recognized by FreeNAS. Any help in
troubleshooting would be much appreciated.
Background info follows:
I am running FreeNAS-8.3.0-RELEASE-p1-x64 (r12825).
ASUS P8Z68 - 16GB DDR3 - ST3000DM001 HD RAID-Z2
I successfully made an rsync backup for my volumes on
a USB3 harddrive (ST2000DM001 in a USB3 enclosure) by
plugging the drive in and then using the volume manager
in the GUI I used the following options
Volume name EXTUSB1
Volume to extend -----
Member disks da1
Filesystem type UFS
This successfully mounted the volume at /mnt/EXTUSB1,
and I was able to backup my data.
I then used the 'Detach Volume' tab in the volumes display
to detach the volume (without checking the "Mark the disks
as new (destroy data)" option).
I subsequently decided to add a second USB thumb drive for
storing scripts using the same procedure as above.
That second thumb drive is USB2 and plugged into a USB2 port.
It shows up on the system with geom label as:
Today I went to plug in my external USB3 drive and it wasn't
recognized.
I have two USB3 ports on the box, and I have tried plugging the drive into
both of them. When I plug the drive in, it spins up, and there is a bit of
noise due to head activity as would be expected when a USB drive is
registered by the system. However there is no sign of the drive and I get
no messages when the drive is plugged in or unplugged from the USB port.
Below is a complete listing of dmesg. I don't see anything, but I have included
just in case there is something that I am missing, and to provide insight into
system configuration.
Volume name EXTUSB1
Member disks da1
Filesystem type UFS
Geom name: da1p2 Providers: 1. Name: ufs/USBDRIVE Mediasize: 5737725440 (5.4G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r1w1e1 secoffset: 0 offset: 0 seclength: 11206495 length: 5737725440 index: 0 Consumers: 1. Name: da1p2 Mediasize: 5737725440 (5.4G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r1w1e2
recognized.
camcontrol devlist -v scbus0 on ahcich0 bus 0: <> at scbus0 target -1 lun -1 () scbus1 on ahcich1 bus 0: <> at scbus1 target -1 lun -1 () scbus2 on ahcich2 bus 0: <ST3000DM001-9YN166 CC9C> at scbus2 target 0 lun 0 (pass0,ada0) <> at scbus2 target -1 lun -1 () scbus3 on ahcich3 bus 0: <ST3000DM001-9YN166 CC4C> at scbus3 target 0 lun 0 (pass1,ada1) <> at scbus3 target -1 lun -1 () scbus4 on ahcich4 bus 0: <ST3000DM001-9YN166 CC4C> at scbus4 target 0 lun 0 (pass2,ada2) <> at scbus4 target -1 lun -1 () scbus5 on ahcich5 bus 0: <ST3000DM001-9YN166 CC47> at scbus5 target 0 lun 0 (pass3,ada3) <> at scbus5 target -1 lun -1 () scbus6 on umass-sim0 bus 0: <Kingston DT Mini Fun G2 PMAP> at scbus6 target 0 lun 0 (pass4,da0) scbus7 on umass-sim1 bus 1: <Lexar JumpDrive 1100> at scbus7 target 0 lun 0 (pass5,da1) scbus-1 on xpt0 bus 0: <> at scbus-1 target -1 lun -1 (xpt0)
freenas# dmesg Copyright (c) 1992-2012 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 8.3-RELEASE-p5 #2 r244158M: Wed Dec 12 10:04:42 PST 2012 root@build.ixsystems.com:/home/jpaetzel/8.3.0/os-base/amd64/usr/home/jpaetzel/8.3.0/FreeBSD/src/sys/FREENAS.amd64 amd64 Timecounter "i8254" frequency 1193182 Hz quality 0 CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz (2608.53-MHz K8-class CPU) Origin = "GenuineIntel" Id = 0x206a7 Family = 6 Model = 2a Stepping = 7 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Features2=0x59ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> AMD Features2=0x1<LAHF> TSC: P-state invariant real memory = 17179869184 (16384 MB) avail memory = 16431353856 (15670 MB) ACPI APIC Table: <ALASKA A M I> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs FreeBSD/SMP: 1 package(s) x 2 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 2 WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ioapic0 <Version 2.0> irqs 0-23 on motherboard kbd1 at kbdmux0 hpt27xx: RocketRAID 27xx controller driver v1.0 (Dec 12 2012 10:04:31) cryptosoft0: <software crypto> on motherboard aesni0: No AESNI support. acpi0: <ALASKA A M I> on motherboard acpi0: [ITHREAD] ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20101013/psargs-464) ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20101013/nsinit-452) acpi0: Power Button (fixed) Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000 acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0 cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0 pci1: <ACPI PCI bus> on pcib1 vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xfe000000-0xfe3fffff,0xc0000000-0xcfffffff irq 16 at device 2.0 on pci0 pci0: <simple comms> at device 22.0 (no driver attached) ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe607000-0xfe6073ff irq 23 at device 26.0 on pci0 ehci0: [ITHREAD] usbus0: EHCI version 1.0 usbus0: <EHCI (generic) USB 2.0 controller> on ehci0 pci0: <multimedia, HDA> at device 27.0 (no driver attached) pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0 pci2: <ACPI PCI bus> on pcib2 pcib3: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0 pci3: <ACPI PCI bus> on pcib3 re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 16 at device 0.0 on pci3 re0: Using 1 MSI-X message re0: Chip rev. 0x2c800000 re0: MAC rev. 0x00000000 miibus0: <MII bus> on re0 rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0 rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow re0: Ethernet address: c8:60:00:6d:86:3b re0: [ITHREAD] pcib4: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0 pci4: <ACPI PCI bus> on pcib4 pcib5: <ACPI PCI-PCI bridge> irq 17 at device 0.0 on pci4 pci5: <ACPI PCI bus> on pcib5 pcib6: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0 pci6: <ACPI PCI bus> on pcib6 ahci0: <ASMedia ASM1061 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xfe500000-0xfe5001ff irq 18 at device 0.0 on pci6 ahci0: [ITHREAD] ahci0: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich0: [ITHREAD] ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich1: [ITHREAD] pcib7: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0 pci7: <ACPI PCI bus> on pcib7 pci7: <serial bus, USB> at device 0.0 (no driver attached) ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe606000-0xfe6063ff irq 23 at device 29.0 on pci0 ehci1: [ITHREAD] usbus1: EHCI version 1.0 usbus1: <EHCI (generic) USB 2.0 controller> on ehci1 isab0: <PCI-ISA bridge> at device 31.0 on pci0 isa0: <ISA bus> on isab0 ahci1: <Intel Cougar Point AHCI SATA controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf060-0xf07f mem 0xfe605000-0xfe6057ff irq 20 at device 31.2 on pci0 ahci1: [ITHREAD] ahci1: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported ahcich2: <AHCI channel> at channel 0 on ahci1 ahcich2: [ITHREAD] ahcich3: <AHCI channel> at channel 1 on ahci1 ahcich3: [ITHREAD] ahcich4: <AHCI channel> at channel 2 on ahci1 ahcich4: [ITHREAD] ahcich5: <AHCI channel> at channel 3 on ahci1 ahcich5: [ITHREAD] pci0: <serial bus, SMBus> at device 31.3 (no driver attached) acpi_button0: <Power Button> on acpi0 acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 900 ppc1: <Parallel port> port 0x378-0x37f irq 5 on acpi0 ppc1: Generic chipset (NIBBLE-only) in COMPATIBLE mode ppc1: [ITHREAD] ppbus0: <Parallel port bus> on ppc1 lpt0: <Printer> on ppbus0 lpt0: [ITHREAD] lpt0: Interrupt-driven port atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 uart0: [FILTER] atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] atkbd0: [ITHREAD] orm0: <ISA Option ROM> at iomem 0xc0000-0xcdfff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 ppc0: cannot reserve I/O port range coretemp0: <CPU On-Die Thermal Sensors> on cpu0 est0: <Enhanced SpeedStep Frequency Control> on cpu0 p4tcc0: <CPU Frequency Thermal Control> on cpu0 coretemp1: <CPU On-Die Thermal Sensors> on cpu1 est1: <Enhanced SpeedStep Frequency Control> on cpu1 p4tcc1: <CPU Frequency Thermal Control> on cpu1 fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8 Timecounters tick every 1.000 msec hpt27xx: no controller detected. usbus0: 480Mbps High Speed USB v2.0 usbus1: 480Mbps High Speed USB v2.0 ugen0.1: <Intel> at usbus0 uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 ugen1.1: <Intel> at usbus1 uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub0: 2 ports with 2 removable, self powered uhub1: 2 ports with 2 removable, self powered ugen0.2: <vendor 0x8087> at usbus0 uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0 ugen1.2: <vendor 0x8087> at usbus1 uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1 uhub2: 6 ports with 6 removable, self powered uhub3: 8 ports with 8 removable, self powered ugen0.3: <Kingston> at usbus0 umass0: <Kingston DT Mini Fun G2, class 0/0, rev 2.00/1.00, addr 3> on usbus0 ugen0.4: <Lexar> at usbus0 umass1: <Lexar JumpDrive, class 0/0, rev 2.00/11.00, addr 4> on usbus0 ada0 at ahcich2 bus 0 scbus2 target 0 lun 0 ada0: <ST3000DM001-9YN166 CC9C> ATA-8 SATA 3.x device ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada1 at ahcich3 bus 0 scbus3 target 0 lun 0 ada1: <ST3000DM001-9YN166 CC4C> ATA-8 SATA 3.x device ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada2 at ahcich4 bus 0 scbus4 target 0 lun 0 ada2: <ST3000DM001-9YN166 CC4C> ATA-8 SATA 3.x device ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada3 at ahcich5 bus 0 scbus5 target 0 lun 0 ada3: <ST3000DM001-9YN166 CC47> ATA-8 SATA 3.x device ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) da1 at umass-sim1 bus 1 scbus7 target 0 lun 0 da1: <Lexar JumpDrive 1100> Removable Direct Access SCSI-0 device da1: 40.000MB/s transfers da1: 7520MB (15400960 512 byte sectors: 255H 63S/T 958C) da0 at umass-sim0 bus 0 scbus6 target 0 lun 0 da0: <Kingston DT Mini Fun G2 PMAP> Removable Direct Access SCSI-0 device da0: 40.000MB/s transfers da0: 3745MB (7669824 512 byte sectors: 255H 63S/T 477C) SMP: AP CPU #1 Launched! GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s). GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s). Trying to mount root from ufs:/dev/ufs/FreeNASs2a ZFS filesystem version 5 ZFS storage pool version 28
