Cronus94
 - Mar 5, 2017
Hi All
I'm in the process of building my first home server which will mainly be used for plex and storage and I have a couple questions about my chosen parts;
Case: Fractal Design Define R5 Case
CPU: Intel Xeon E3-1231 v3
Motherboard: Supermicro X10SL7-F (or other if you can recommend one)
RAM: Samsung DDR3 ECC 8Gb x2 (possibly might go for 32gb instead)
Power Supply: SeaSonic G-550
Additional Fans: Noctua PWM Fans
Storage: WD RED 4TB drives x3 (maby 4)
Firstly will I need to cross flash the board to IT mode for the on board LSI?
Secondly whats the difference between Supermicro X10SL7-F and Supermicro MDB-X10SL7-F-O?
Will this work as a plex home server?
And do you have any suggestions or things i should consider?
Also haven't decided yet if a SATA DOM, Thumb Drive or SSD is best for the boot drive.
