File "/usr/lib/python3/dist-packages/middlewared/job.py", line 378, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 414, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1001, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 1589, in do_create
data = await self.map_functions[create_type](job, data)
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 1676, in create_csr
req, key = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1239, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1207, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1111, in run_in_executor
File "/usr/lib/python3/dist-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1005, in nf
return f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 567, in generate_certificate_signing_request
csr = self.add_extensions(csr, data.get('cert_extensions', {}), key, None)
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 244, in add_extensions
klass(*self.get_extension_params(extension, cert, issuer)),
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 265, in get_extension_params
issuer.public_key() if issuer else cert._public_key
AttributeError: 'CertificateSigningRequestBuilder' object has no attribute '_public_key'
@Nate W I've no idea what you're doing, but you're clearly doing more than just follow the instructions.
The instructions asume all settings that are not meantioned are not touched. That whole screenshot isn't even available while following the instructions.
No, no assumptions are made.I did follow the directions. I can screen cap if you really want it. Perhaps some assumptions are being made in the directions?
File "/usr/lib/python3/dist-packages/middlewared/plugins/acme_protocol_/issue_cert.py", line 101, in issue_certificate
return acme_client.poll_and_finalize(
File "/usr/lib/python3/dist-packages/acme/client.py", line 710, in poll_and_finalize
orderr = self.poll_authorizations(orderr, deadline)
File "/usr/lib/python3/dist-packages/acme/client.py", line 734, in poll_authorizations
raise errors.ValidationError(failed)
acme.errors.ValidationError
await self.future
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 1584, in do_create
data = await self.middleware.run_in_thread(
File "/usr/lib/python3/dist-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/lib/python3/dist-packages/middlewared/plugins/crypto.py", line 1639, in __create_acme_certificate
final_order = self.middleware.call_sync('acme.issue_certificate', job, 25, data, csr_data)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1266, in call_sync
return methodobj(*prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/acme_protocol_/issue_cert.py", line 117, in issue_certificate
raise CallError(f'Certificate request for final order failed: {msg}')
middlewared.service_exception.CallError: [EFAULT] Certificate request for final order failed:
Authorization for identifier Identifier(typ=IdentifierType(dns), value='mydomain.com') failed.
Here are the challenges that were not fulfilled:
Challenge Type: dns-01
Error information:
- Type: urn:ietf:params:acme:error:unauthorized
- Details: No TXT record found at _acme-challenge.mydomain.comAlright, progress!
This is more for the iX folks at this point:
Is there a good way to validate that cloudflare creds are working? I am using the API key as stated, have 1.1.1.1 for the dns and tried a reboot. It looks like it is not successfully creating the TXT record for the challenge.
iX uses Jira not github issues.
Actually: No not really.Any containers/apps would need a different solution, though.
I have no idea if the API for SCALE supports the same endpoints that it does in CORE. If it does, my Let's Encrypt deployment script would handle the TrueNAS GUI:
GitHub - danb35/deploy-freenas: Python script to automate deploying TLS certificates to TrueNAS servers
Python script to automate deploying TLS certificates to TrueNAS servers - danb35/deploy-freenasgithub.com
I'd do the same--better to use the integrated solution if it does what you need it to.Looks like CloudFlare is native in 21.04 though so I will probably switch over to that.
It's a bit odd though, he registered an account to comment this, but neglected to read 3 posts higher and notice it's severely bugged in 21.04 :')I'd do the same--better to use the integrated solution if it does what you need it to.
