I have installed a Debian VM that does not start automatically.
There is a tutorial: https://www.truenas.com/docs/scale/scaletutorials/virtualization/creatingmanagingvmsscale/
I have edited the startup.nsh. If I start startup.nsh manually, then it works.
In my case, the startup.nsh is probably at the wrong place.
# FSO/EFI/Debian
But I can't create or edit the file anywhere else.
This works.The grub file does not run when you start the VM, you can do this manually after each start. At the shell prompt:
- Type FS0: Return.
- Type cd EFI Return.
- Type cd Debian Return.
- Type grubx64.efi Return.
This does not work.To ensure it starts automatically, you create the startup.nsh file at the root directory on the vm. To create the file:
- Go to the Shell.
- At the shell prompt type edit startup.nsh.
- In the editor type:
- Type FS0: Return.
- Use the Control+s keys (Command+s for Mac OS) then Return.
- Use the Control+q keys to quit.
- Close the display window
- To test if it now boots up on startup:
- Power off the VM.
- Click Start.
- Click Display.
- Log into your Debian VM.
# FSO/EFI/Debian
