I thought all that stuff was going to be fixed in B3, is it RC1?
What's the ticket / job# on the tracker?
No, what's fixed is Linux VMs with kernel > 4.15. Otherwise, no change to the UEFI limitations.
d-i preseed? Not for the casual user then. But just use expert install, surely that's easier than mounting then copying an ios , changing the preseed file and then generating a new iso.
Oh I'm confusing the issues, sorry. Thanks Kris.
When you say 'limitations' is this a long term thing then?
OK. So, I have been attempting the prescribed fix for VM boot problems, in my case on Debian stretch. Creating the directories and copying the efi file do not result in boot - still stops with the EFI manager.
I was looking for any updates or idea when to expect a fix. Is there somewhere this is being tracked? Or do I bail on Debian for CentOs or other distribution for my VMs ?
grub-install --efi-directory=/boot/efi --boot-directory=/boot --removableFailed to set MokListRT: Invalid Parameter Something has gone seriously wrong: import_mok_state() failed: Invalid Parameter
cp /boot/efi/EFI/centos/grubx64.efi /boot/efi/EFI/BOOT/BOOTX64.EFI sync;sync;sync poweroff
So, the UEFI-CSM was supposed to make it a BIOS like environment. However, when installing Centos 7 I can't do the Web VNC to do the install. How are we supposed to get the console for the VM if it's not UEFI?
Thanks for posting this, but it's more accurate to say it's a new Centos UEFI issue as described here: https://bugs.centos.org/view.php?id=15522
Failed to set MokListRT: Invalid Parameter Something has gone seriously wrong: import_mok_state() failed : Invalid Parameter
I've seen this post, but I can't even get to the part of booting into that troubleshooting because the serial console from the GUI does nothing and neither does looking via VNC. I simply can't even install the OS on this dumb empty disk...@renzomarcus See #147 & #148 above
Thank you very much, I missed the part of installing an older machine first. Wow this is tricky, let's hope not everything on FreeNAS requires you to troubleshoot the hell out of it :D
It's Centos's fault actually -_-
