Warden and Iocage jails
Samuel Tai
Can you describe how your second FreeNAS server was set up? There’s not enough info to go by currently.
sakn54
also, should I delete the jail I created for plex in iocage and associated users. I am running my plexserver for tv shows in warden. Big problem is that I can"t add anything to it because I can't access my
sakn54
I followed the freenas video on installing plex in 11.2.Everything went fine until plex after picking up the tv shows then they dissapeared. I tried looking at the shares I created in the dataset, but could not find anything. I must have changed something in the share settings that cause my media files to become inaccessable. Any help will be appreciated.
sakn54
I have tried numerous fixes to enable permissions. None of them worked.
Samuel Tai
Again, stop panicking. Please describe in detail how the second FreeNAS server running plex was set up. You haven’t provided enough information for anyone here to help yet.
sakn54
i used existing dataset from warden jail. i added a user, and then i edited an existing share. After that I lost access to freenas media.
Samuel Tai
Still not enough information. This is what we need: The layout of the datasets in the pool. Please provide the output of zfs list.
i added a user
Which user did you add, and how did you define the user's home directory?
Which specific share did you edit, and what did you do to it?
sakn54
I created plexuser in user account with media as full name, plexuser as username.
I am showing screen shots
Samuel Tai
For screenshot 51, you forgot to check "Apply permissions recursively".
Samuel Tai
For screenshot 50, your user is actually plexmedia, not plexuser.
Samuel Tai
Your choice. Just make sure the share is owned by the correct user and group, and has the correct permissions.
sakn54
Just deleted share and created a new one. The new share appears in explorer, but access denied. I can't understand why.
sakn54
this is what i get when trying to access folder
Samuel Tai
For guest access, make sure you set recursive permissions on the folder to allow read/write/execute to others.
Samuel Tai
Remember to restart SMB service after making changes to share permissions.
sakn54
I am susupecting it's something I did in my freenas setting up the plex. I can't reach my shared file in my mac and windows. I just can't see what i did wrong. Probably something dumb
