Hi
I have just setup FreeNAS for the first time and have searched the forums and cannot find an answer to my problem. So I apologise in advance if this is a typical newbie question.
FreeNAS boots OK off my hard drives. I can see the drives in View Disks and also from the command line if I run cam control devlist and gpartshow.
But when go into Volume Manager it cannot find any drives upon which to set up volumes.
I am using a Dell PowerEdge T20 with 2 x Seagate 6 TB ST6000DM004 BarraCuda Pro 3.5 drives.
All RAID functionality is turned off in the BIOS.
Thank you
Thank you
