Volume Degraded - Disk removed from pool
bornstellare
Hello All,
My ada5 disk keeps falling off of my pool. This is the third time. I get the following error on the GUI when it happens:
CRITICAL: Aug. 7, 2017, 10:55 p.m. - The volume tank state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The pool status is as follows:
root@freenas:/var/log # zpool status tank
pool: tank
state: DEGRADED
status: One or more devices has been removed by the administrator.
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0 in 6h45m with 0 errors on Mon Aug 7 21:15:06 2017
NAME STATE READ WRITE CKSUM
tank DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/2dc7c53c-2b99-11e6-94d8-0015177adaa2.eli ONLINE 0 0 0
gptid/2e7247c8-2b99-11e6-94d8-0015177adaa2.eli ONLINE 0 0 0
gptid/2f1f7b49-2b99-11e6-94d8-0015177adaa2.eli ONLINE 0 0 0
17205288451372208862 REMOVED 0 0 0 was /dev/gptid/85cd4d9b-786d-11e7-8c12-0015177adaa2.eli
gptid/306d3755-2b99-11e6-94d8-0015177adaa2.eli ONLINE 0 0 0
errors: No known data errors
Looking at the log around the time disk dropped off, this is what I can find related to ada5.
Aug 7 22:55:01 freenas ada5 at ahcich9 bus 0 scbus8 target 0 lun 0
Aug 7 22:55:01 freenas ada5: <ST3000DM008-2DM166 CC26> s/n Z504HT97 detached
Aug 7 22:55:01 freenas GEOM_ELI: Device ada5p1.eli destroyed.
Aug 7 22:55:01 freenas GEOM_ELI: Detached ada5p1.eli on last close.
Aug 7 22:55:01 freenas GEOM_ELI: Device gptid/85cd4d9b-786d-11e7-8c12-0015177adaa2.eli destroyed.
Aug 7 22:55:01 freenas GEOM_ELI: Detached gptid/85cd4d9b-786d-11e7-8c12-0015177adaa2.eli on last close.
Aug 7 22:55:01 freenas (ada5:ahcich9:0:0:0): Periph destroyed
Aug 7 22:55:02 freenas ZFS: vdev state changed, pool_guid=1878614223730411841 vdev_guid=17205288451372208862
Aug 7 22:55:06 freenas ada5 at ahcich9 bus 0 scbus8 target 0 lun 0
Aug 7 22:55:06 freenas ada5: <ST3000DM008-2DM166 CC26> ACS-2 ATA SATA 3.x device
Aug 7 22:55:06 freenas ada5: Serial Number Z504HT97
Aug 7 22:55:06 freenas ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
Aug 7 22:55:06 freenas ada5: Command Queueing enabled
Aug 7 22:55:06 freenas ada5: 2861588MB (5860533168 512 byte sectors)
Aug 7 22:55:06 freenas ada5: quirks=0x1<4K>
There does not seem to be any errors on the disk.
# smartctl -x /dev/ada5
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST3000DM008-2DM166
Serial Number: Z504HT97
LU WWN Device Id: 5 000c50 0a26fea84
Firmware Version: CC26
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Aug 7 23:22:31 2017 PDT
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
General SMART Values:
was never started.
been run.
data collection: ( 80) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 316) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 117 099 006 - 165453552
3 Spin_Up_Time PO---- 096 094 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 45
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 072 060 030 - 16440065
9 Power_On_Hours -O--CK 099 099 000 - 1325
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 27
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0
189 High_Fly_Writes -O-RCK 096 096 000 - 4
190 Airflow_Temperature_Cel -O---K 066 054 045 - 34 (Min/Max 34/35)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 5
193 Load_Cycle_Count -O--CK 100 100 000 - 95
194 Temperature_Celsius -O---K 034 046 000 - 34 (0 19 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 1325 (247 179 0)
241 Total_LBAs_Written ------ 100 253 000 - 15404867691
242 Total_LBAs_Read ------ 100 253 000 - 127759997849
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 SATA NCQ Queued Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 20 Device vendor specific log
0xa2 GPL VS 4496 Device vendor specific log
0xa8 GPL,SL VS 129 Device vendor specific log
0xa9 GPL,SL VS 1 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 5176 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL,SL VS 10 Device vendor specific log
0xc3 GPL,SL VS 8 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 34 Celsius
Power Cycle Min/Max Temperature: 34/35 Celsius
Lifetime Min/Max Temperature: 19/46 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Is there anything else I can check on why this disk keeps dropping off? It's a relatively new disk which I bought around 4 months ago.
Thanks for any input.
nojohnny101
Do you have any RAID cards between the disks and the motherboard?
bornstellare
Thanks for the replies.
I don't have any RAID cards. The drives connect directly to the motherboard's SATA ports.
All the cables are properly secured. I have, for now, swapped the SATA cable with a new one and connected power from a different cable.
I'll watch out for few days to see if it happens again.
bornstellare
OK, after much troubleshooting, it appears one of the SATA ports on the motherboard is misbehaving.
I have moved drives off it for now. So far, so good. Let's see if that helps ...
