Kevin Horton
- Dec 2, 2015
I have a disk that has not been found by FreeNAS after system boot on the last two occurences. Normally the server runs continously, and it had been running without error since the last boot, to update to FN 11.1-U6. I shut it down to move it a few days ago, and disk /dev/da4 was not found after start up, and that RAIDZ2 pool was degraded. I rebooted the server, and the disk was found. FreeNAS did a very quick resilver, which completed successfully, but reporting 3 checksum errors on that disk. The SMART data looked good, and the disk passed a long test without error, so I did a
After that event, everything was fine until now. We went on the road for several days, and I elected to shut the server down, as it would not be possible to provide timely response to any HW failures (fan failures, etc). I rebooted the server after returning home, and the same disk was not available. It took two reboots before it finally appeared. Once again it resilvered, and showed two checksum errors, which I cleared.
The current SMART report is:
That pool is scheduled to run its weekly long test tonight. We'll see if any new issues are reported.
Other than checking that the power and data cables are secure, is there anything else I should check?
Is this a sign that the disk is getting ready to fail? I'm not seeing any other warning signs, so I'm guessing the disk isn't getting close to end of life.
I've got a new disk all burned in, ready to go if it fails. I've got four backups of the data, two of which are fresh, and the other two less than a week old.
zpool clear <pool name>. After that event, everything was fine until now. We went on the road for several days, and I elected to shut the server down, as it would not be possible to provide timely response to any HW failures (fan failures, etc). I rebooted the server after returning home, and the same disk was not available. It took two reboots before it finally appeared. Once again it resilvered, and showed two checksum errors, which I cleared.
% smartctl -x /dev/da4 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E7JD09SA LU WWN Device Id: 5 0014ee 2629e18a6 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Nov 24 14:24:16 2018 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Unavailable Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (51840) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 518) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x703d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 184 175 021 - 7791 4 Start_Stop_Count -O--CK 100 100 000 - 83 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 079 079 000 - 15640 10 Spin_Retry_Count -O--CK 100 253 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 83 192 Power-Off_Retract_Count -O--CK 200 200 000 - 38 193 Load_Cycle_Count -O--CK 200 200 000 - 383 194 Temperature_Celsius -O---K 120 112 000 - 32 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 100 253 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb6 GPL,SL VS 1 Device vendor specific log 0xb7 GPL,SL VS 39 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 93 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 15627 - # 2 Short offline Completed without error 00% 15603 - # 3 Extended offline Completed without error 00% 15591 - # 4 Extended offline Completed without error 00% 15574 - # 5 Short offline Completed without error 00% 15561 - # 6 Short offline Completed without error 00% 15537 - # 7 Short offline Completed without error 00% 15513 - # 8 Short offline Completed without error 00% 15489 - # 9 Short offline Completed without error 00% 15465 - #10 Short offline Completed without error 00% 15441 - #11 Short offline Completed without error 00% 15417 - #12 Extended offline Completed without error 00% 15408 - #13 Short offline Completed without error 00% 15393 - #14 Short offline Completed without error 00% 15369 - #15 Short offline Completed without error 00% 15345 - #16 Short offline Completed without error 00% 15321 - #17 Short offline Completed without error 00% 15297 - #18 Short offline Completed without error 00% 15273 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: Active (0) Current Temperature: 32 Celsius Power Cycle Min/Max Temperature: 30/32 Celsius Lifetime Min/Max Temperature: 3/40 Celsius Under/Over Temperature Limit Count: 0/0 Vendor specific: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (440) Index Estimated Time Temperature Celsius 441 2018-11-24 06:27 37 ****************** ... ..(178 skipped). .. ****************** 142 2018-11-24 09:26 37 ****************** 143 2018-11-24 09:27 38 ******************* ... ..( 25 skipped). .. ******************* 169 2018-11-24 09:53 38 ******************* 170 2018-11-24 09:54 ? - 171 2018-11-24 09:55 30 *********** ... ..( 5 skipped). .. *********** 177 2018-11-24 10:01 30 *********** 178 2018-11-24 10:02 31 ************ ... ..( 2 skipped). .. ************ 181 2018-11-24 10:05 31 ************ 182 2018-11-24 10:06 32 ************* 183 2018-11-24 10:07 32 ************* 184 2018-11-24 10:08 32 ************* 185 2018-11-24 10:09 38 ******************* ... ..(140 skipped). .. ******************* 326 2018-11-24 12:30 38 ******************* 327 2018-11-24 12:31 37 ****************** ... ..(112 skipped). .. ****************** 440 2018-11-24 14:24 37 ****************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP/SMART Log 0x04) not supported Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x0008 2 0 Device-to-host non-data FIS retries 0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy 0x000a 2 2 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x000f 2 0 R_ERR response for host-to-device data FIS, CRC 0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC 0x8000 4 883 Vendor specific
