vfs.zfs.arc_max ignored
crkinard
Trying to increase RAM usage when it comes to the ARC. Setting ti higher than the default half my RAM.
System Settings -> Advanced -> Sysctl
Reboot and there is no change in usage or in 'arc_summary -s arc'.
Am I doing something wrong?
cwagz
I think it gets reset every time you start or stop a VM. Maybe even on a schedule. I could not get a change to stick.
HunorR
Personally i just added the following line to Init/Shutdown Script`s : echo 34359738368 > /sys/module/zfs/parameters/zfs_arc_max
and it works for me
Etorix
Read here:
The cap at half the RAM in SCALE is forced upon by the Linux kernel allocator. (CORE can have a higher limit :wink:)
crkinard
and it works for me
Thats what I was doing but I thought it was not the 'proper' way to do it.
Read here:
Ahh so its not just the default. It is the 'forced default'.
