[Urgent] Freenas throws errors and does not want to start
adam23450
I have a problem with freenas. It won't start. Crashes some bugs. I formatted the system and now it won't move. This is not the first time he does this. Pictures in the attachment. Please help. All my debts are currently lying. Nothing can be used. Help!
Redcoat
Please first provide details of your FreeNAS hardware and FreeNAS version as described in Forum Rules tab above.
adam23450
Amd Athlon 3000G processor
RAM: 64 GB DDR4 2666 MHz - GoodRam
Drives: Seagate IronWolf 4TB, WD 280 GB, SSD Adata 128 GB WD Green SSD - 240 GB - System
Motherboard: Gigabyte AB350M-DS3H V2
TP-Link TG-3468 network card
FreeNAS® 11.3-U4
Redcoat
What is on the console screen when you reboot?
adam23450
Redcoat
So not the screen that shows the IP addresses of the GUI (and the 1-11 list of options)?
adam23450
When I enter the address 192.168.0.9 it shows that freenas does not answer
Redcoat
What were you doing on your FreeNAS system before you lost the ability to log on to it? What changes or modifications did you make to any settigs or configuration?
adam23450
This is where the problem is because I haven't made any changes.
adam23450
When we post here on the forum I am restoring my freenas services. I reinstalled the system and there is an error again (photo). This time I imported my disks. It was good so far. Then I created the virtual machine it was fine. I started the Prison with nextcloud it was fine and after chiwli everything fell out.
Redcoat
So you started a Nextcloud jail and it was fine, then you did something else and the system was not fine. What was the "something else"? Says "chiwli" here and that doesn't mean anything to me.
adam23450
After setting up the prison, I did nothing.
Redcoat
When the system was fine before you set up the Nextcloud jail, could you access your mapped drives from your Windows client machine?
adam23450
Yes
Redcoat
This suggests to me that the problem is with that Jail.
If this were my system I would reinstall FreeNAS, import the pool to a clean configuration, destroy the existing Nextcloud jail (without starting it) and create a new Nextcloud jail using @danb35 's script.
Other people here with more experience that I may be able to give you better suggestions, but that's my best idea right now.
adam23450
I just installed the latest FreeNas and imported the pools. Now he shows me that my seagate is unavailable [...]
Redcoat
Yes, that's what it seemed to show in one of your screenshots. That's why I asked you if everything was fine and you could connect to your mapped drives before you started the Nextcloud jail.
What does camcontrol devlist give you?
adam23450
this :)
Redcoat
zpool status -v?
adam23450
root@dom[~]# zpool status -v
  pool: Maszyny
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:12:25 with 0 errors on Sun Sep 13 00:12:25 2020
        NAME                                          STATE     READ WRITE CKSUM
        Maszyny                                       ONLINE       0     0     0
          gptid/2bc01a86-6b69-11ea-b865-b42e9967ad61  ONLINE       0     0     0
errors: No known data errors
  pool: SSD
 state: ONLINE
  scan: none requested
        SSD                                           ONLINE       0     0     0
          gptid/7c785197-0413-11eb-8ad5-b42e9967ad61  ONLINE       0     0     0
  pool: Seagate_4TB
 state: ONLINE
  scan: scrub repaired 0 in 0 days 04:49:23 with 0 errors on Sun Sep 20 04:49:23 2020
        Seagate_4TB                                   ONLINE       0     0     0
          gptid/5cdfdf76-5307-11ea-a568-b42e9967ad61  ONLINE       0     0     0
  pool: freenas-boot
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
        freenas-boot  ONLINE       0     0     0
          ada3p2    ONLINE       0     0     1
