I will be upfront, I don't think this is Truenas' fault, but I don't know any workarounds for this or even if that supposition is correct.
I have an expansion card:
SupaHub SATA Card 8 Port, Non Raid SATA Expansion Card for SATA III 6G Hard Drives for Desktop, Includes 8 SATA Cables and 2 SATA Splitter Cables
It is not the best in the word, but it worked fine on my old motherboard. I upgraded to an Gigabyte Aurous Master z690 - and I can see in the system info that the Bios recognises that something is plugged into the PICEx4_1: PCIe 2.0 x1 @ 2.0 x1.
However, the bios only shows 6 SATA drives in the standard motherboard ports, and there are another 3 plugged into that expansion card - but these are not seen by the bios.
I think, though I am not 100% sure, that this is causing me a problem when I try and boot into Truenas - as I keep getting a boot error, and I am wondering whether it is because Truenas is expecting to see 9 drives as that was the configuration the last time it booted up?
Currently, I am getting a KDB enter panic when booting, with a cpu_reset but the messages are flashing past so fast it is hard to tell exactly what is happening.
I was just wondering if anyone had encountered a similar problem and knew of a workaround?
Or if anyone knew what I should look at to narrow down on the issue. Thanks.
