I recently received an email from Plex about the need to update my plex server. I found that I couldn't perform an update using pkg because the jail was running 11.2-RELEASE.
I decided to upgrade the jail to the 11.3 release by running
Additionally,
I forgot to run
I assume I missed a step to finish off the upgrade although I'm not sure. Any help would be great.
Current FreeNAS version: 11.2-U7
iocage upgrade -r 11.3-RELEASE plex
. It took a while but it seemed to complete without an error (or at least none that I noticed). However, when I try to update pkg, I don't see any new packages.Additionally,
iocage list
seems to list the jail as 11.3 but uname -a within the jail and the MOTD still list 11.3-RELEASE:Code:
--$ sudo iocage list +-----+---------------+-------+--------------+-------------+ | JID | NAME | STATE | RELEASE | IP4 | +=====+===============+=======+==============+=============+ | 8 | plex | up | 11.3-RELEASE | 10.0.0.20 | +-----+---------------+-------+--------------+-------------+ user@freenas:~ : |--$ sudo iocage console plex ... root@plex:~ # uname -a FreeBSD plex 11.2-STABLE FreeBSD 11.2-STABLE #0 r325575+c9231c7d6bd(HEAD): Mon Nov 18 22:46:47 UTC 2019 root@nemesis:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64 root@plex:~ # pkg update Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. root@plex:~ # pkg upgrade Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date
I forgot to run
iocage update plex
so I'm not sure if that's the problem.I assume I missed a step to finish off the upgrade although I'm not sure. Any help would be great.
