Nagios4 in iocage jail
rwfitzy
I am running 11.1-U6 and have the nagios4 package installed via pkg and the version is 4.4.1, which apparently has a bug and I've been told I should upgrade to 4.4.2. If I try pkg upgrade it says all is up to date, but if I check the distinfo file in the ports folder, it shows 4.4.2:
root@monitor:/usr/ports/net-mgmt/nagios4 # pkg upgrade
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
All repositories are up to date.
Checking for upgrades (10 candidates): 100%
Processing candidates (10 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
root@monitor:/usr/ports/net-mgmt/nagios4 # pkg info nagios4 | grep Version
Version		: 4.4.1,1
root@monitor:/usr/ports/net-mgmt/nagios4 # cat distinfo
TIMESTAMP = 1535968827
SHA256 (nagios-4.4.2.tar.gz) = 3418923f326aa86dc8c84cfd0df788fa495a90d772f8071acf40fdbef0736853
SIZE (nagios-4.4.2.tar.gz) = 11301454
I have ran portsnap fetch and portsnap update, does this mean I should uninstall the pkg version and build from ports to get this version or is there some way to get pkg to use the latest available?
