getting errors using pkg on main system
pitt1717
so after upgrading some other components in my network i decided to move from 9.3 to 9.10. After which i thought, let me see if i can install minicom to act as a pseudo term server for my cisco switch and can decor an old laptop.
anyway, i tried upgrading pkg but get an error. not sure if this is 9.10 specific or not, but not sure how to fix it. can anyone else check their pkg system on freenas itself. i.e. not in a jail
thanks
[root@vpdnas01] ~# pkg upgrade
Updating local repository catalogue...
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
All repositories are up-to-date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
pirateghost
Unintelligible Geek
You aren't supposed to install anything on FreeNAS. You are supposed to use jails.
