Upgrade to 11.2Beta not sure what all this is
Rickinfl
Upgraded to 11.2Beta and All these folders showed up. What's going on?
garm
That is the dataset created by the new jail manager, iocage.
Rickinfl
Then what is the Download and Releases? Can I delete those? I didn't create them.
garm
Iocage created the dataset. You won’t be able to delete it.
Alecmascot
root@freenas2:~ # iocage clean --help
Usage: iocage clean [OPTIONS]
  Destroy specified dataset types.
Options:
  -f, --force	 Runs the command with no further user interaction.
  -a, --all	   Destroy all iocage data that has been created.
  -j, --jails	 Destroy all jails created.
  -r, -b, --base  Destroy all RELEASEs fetched.
  -t, --template  Destroy all templates.
  --help		  Show this message and exit.
root@freenas2:~ #
