Grasfer
- Jun 19, 2015
Hi, updated murmur from murmur: 1.2.8_1 -> 1.2.10 and now when i try to start it it complains about segmentation fault.
Tried removing and reinstall but still same error.
Never got a error like that before so no idea where to start. Started googling but only found people with broken usb's/boot devices. Got my jails on a dedicated SSD.root@server:/ # service murmur start
Starting murmur.
Segmentation fault
/usr/local/etc/rc.d/murmur: WARNING: failed to start murmur
The following 2 package(s) will be affected (of 0 checked): New packages to be INSTALLED: openssl: 1.0.2_4 Installed packages to be UPGRADED: murmur: 1.2.8_1 -> 1.2.10 The process will require 11 MiB more space. 3 MiB to be downloaded. Proceed with this action? [y/N]: n root@server:/ # service mumble stop mumble does not exist in /etc/rc.d or the local startup directories (/usr/local/etc/rc.d) root@server:/ # cat /etc/rc.conf portmap_enable="NO" sshd_enable="NO" sendmail_enable="NO" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" hostname="server" devfs_enable="YES" devfs_system_ruleset="devfsrules_common" inet6_enable="YES" ip6addrctl_enable="YES" murmur_enable="YES" znc_user="znc-admin" znc_enable="yes" znc_conf_dir="/usr/home/znc-admin/.znc" nginx_enable="YES" php_fpm_enable="NO" mysql_enable="NO" syslogd_enable="NO" syslogd_program="/usr/sbin/syslogd" syslogd_flags="-ss" root@server:/ # service murmur stop Stopping murmur. Waiting for PIDS: 7737. root@server:/ # pkg upgrade Updating FreeBSD repository catalogue... FreeBSD repository is up-to-date. All repositories are up-to-date. Checking for upgrades (2 candidates): 100% Processing candidates (2 candidates): 100% The following 2 package(s) will be affected (of 0 checked): New packages to be INSTALLED: openssl: 1.0.2_4 Installed packages to be UPGRADED: murmur: 1.2.8_1 -> 1.2.10 The process will require 11 MiB more space. 3 MiB to be downloaded. Proceed with this action? [y/N]: y [server] Fetching murmur-1.2.10.txz: 100% 390 KiB 400.2kB/s 00:01 [server] Fetching openssl-1.0.2_4.txz: 100% 2 MiB 1.4MB/s 00:02 Checking integrity... done (0 conflicting) [server] [1/2] Installing openssl-1.0.2_4... [server] [1/2] Extracting openssl-1.0.2_4: 100% [server] [2/2] Upgrading murmur from 1.2.8_1 to 1.2.10... You may need to manually remove /usr/local/etc/murmur.ini if it's no longer needed. ==> You should manually remove the "murmur" user. ===> Creating users and/or groups. Using existing group 'murmur'. Using existing user 'murmur'. [server] [2/2] Extracting murmur-1.2.10: 100% Message from openssl-1.0.2_4: Copy /usr/local/openssl/openssl.cnf.sample to /usr/local/openssl/openssl.cnf and edit it to fit your needs. root@server:/ # service murmur start Starting murmur. Segmentation fault /usr/local/etc/rc.d/murmur: WARNING: failed to start murmur root@server:/ # cat /etc/rc.conf portmap_enable="NO" sshd_enable="NO" sendmail_enable="NO" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" hostname="server" devfs_enable="YES" devfs_system_ruleset="devfsrules_common" inet6_enable="YES" ip6addrctl_enable="YES" murmur_enable="YES" znc_user="znc-admin" znc_enable="yes" znc_conf_dir="/usr/home/znc-admin/.znc" nginx_enable="YES" php_fpm_enable="NO" mysql_enable="NO" syslogd_enable="NO" syslogd_program="/usr/sbin/syslogd" syslogd_flags="-ss" root@server:/ # updatedb >>> WARNING >>> Executing updatedb as root. This WILL reveal all filenames >>> on your machine to all login users, which is a security risk. root@server:/ # locate murmur.ini /usr/local/etc/murmur.ini /usr/local/etc/murmur.ini.sample root@server:/ # service murmur start Starting murmur. Segmentation fault /usr/local/etc/rc.d/murmur: WARNING: failed to start murmur root@server:/ # service murmur start Starting murmur. Segmentation fault /usr/local/etc/rc.d/murmur: WARNING: failed to start murmur root@server:/ # pkg remove murmur Checking integrity... done (0 conflicting) Deinstallation has been requested for the following 1 packages (of 0 packages in the universe): Installed packages to be REMOVED: murmur-1.2.10 The operation will free 1 MiB. Proceed with deinstalling packages? [y/N]: y [server] [1/1] Deinstalling murmur-1.2.10... You may need to manually remove /usr/local/etc/murmur.ini if it is no longer needed. ==> You should manually remove the "murmur" user. [server] [1/1] Deleting files for murmur-1.2.10: 100% root@server:/ # pkg install murmur Updating FreeBSD repository catalogue... FreeBSD repository is up-to-date. All repositories are up-to-date. Checking integrity... done (0 conflicting) The following 1 package(s) will be affected (of 0 checked): New packages to be INSTALLED: murmur: 1.2.10 The process will require 1 MiB more space. Proceed with this action? [y/N]: y [server] [1/1] Installing murmur-1.2.10... ===> Creating users and/or groups. Using existing group 'murmur'. Using existing user 'murmur'. [server] [1/1] Extracting murmur-1.2.10: 100% root@server:/ # service murmur start Starting murmur. Segmentation fault /usr/local/etc/rc.d/murmur: WARNING: failed to start murmur
