DrKK
FreeNAS Generalissimo
- Oct 15, 2013
If you have done any of your own personal jail installations on FreeNAS (e.g., murmur, ZNC, whatever), then you have a high likelihood of having an atypical perl (typically 5.18) installed in your jail by ports or packages.
As of a couple days ago, there was a substantial change (in the direction of more fascist) to how default perl versions work, where they can be installed, how they can be installed, and how they must be built, etc. I may have triggered this by pointing something out in #freebsd the other day (whoops), so there is a possibility that it's my fault. :(
Thus, you may have discovered that your portmaster build for perl is suddenly breaking, and if that breaks, everything else won't build.
The solution is little bit of a pain in the ass, and the details of it were provided in the "UPDATING" errata that comes with the ports tree. I copy the relevant section here for your perusal---I am myself rebuilding now, and it seems to be working after following the instructions:
When they say, "it will break everything", believe me, it will completely break everything. Also, as to this part:
more than likely you *do* have your perl named perl5.xx-5.xx.y, and will have to make this change. To find out what your perl pkg is named:
root@murmur:/tmp # grep -A 33 20150914 /usr/ports/UPDATING 20150914: AFFECTS: users of lang/perl5* AUTHOR: mat@FreeBSD.org Binary package users can ignore this. The way lang/perl5* ports install themselves has changed. From now on, only the default Perl port (currently 5.20), or the version listed in DEFAULT_VERSIONS, will install /usr/local/bin/perl. If you are NOT using the default version of Perl (as of right now, it is 5.20) you MUST add a line setting the version you are using to your /etc/make.conf, to preserve /usr/local/bin/perl: DEFAULT_VERSIONS+= perl5=5.xx If your Perl package name is not called perl5-5.xx.y but perl5.xx-5.xx.y, you will need to rename it so that portupgrade and portmaster do not get confused: pkg set -n perl5.xx:perl5 After this date, to migrate from one Perl version to the other, you must first put the DEFAULT_VERSIONS line in your make.conf, and then, for example, if you want to move from 5.20 to 5.22, do: pkg set -o lang/perl5.20:lang/perl5.22 portmaster `pkg shlib -qR libperl.so.5.20` If you do not do that, you will replace your default Perl 5.20 installation (one that has /usr/local/bin/perl) with an installation that does not have /usr/local/bin/perl, and it will break everything.
pkg info | grep perl
