smartd not starting after FreeNAS-9.3-STABLE-201506292130 update
dash
Hey All,
First time poster, long time lurker.
Have a server I have been getting ready to use for storing backups. Saw there was an update notification this morning and updated through the autoupdate without thinking twice.
On boot smartd was alerting and checked the logs it failed to start.
I was able to click it off in the WebGUI, but not turn it back on, prompting Server Failed to Start. Starting it on the CLI shows:
service smartd start
Will not 'start' smartd because smartd_enable is NO.
In /val/log/messages it shows:
nas notifier: Starting smartd.
nas smartd[13530]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries (like /dev/hda)
nas root: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
nas notifier: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
Server specs are:
Build FreeNAS-9.3-STABLE-201506292130
Platform Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
Memory 32697MB
Let me know what else I am missing or if I need to post a log. Thanks in advance.
DJ9
Sounds like a bug if you can't re-enable it via the GUI. You should be able to put it into the rc.conf so it looks like this:
smartd_enable="YES"
And then run "service smartd start" (minus the quotes) and see if that works as a temporary fix.
dash
@Ericloewe yes, that looks like the same issue. Did he report it as a bug? Would like me to do the same?
@DJ9 No luck... :(
smartd_enable="YES"
/etc/rc.conf: 74 lines, 1694 characters.
[root@nas] ~# service smartd start
  • Like
Reactions: DJ9
diskmaster23
I am having the same issue, except mine doesn't report buggy like the op. I cannot seem to find a solution.
[root@freenas] ~# uname -a
FreeBSD freenas.local 9.3-RELEASE-p28 FreeBSD 9.3-RELEASE-p28 #0 r288272+f229c79: Sat Dec 12 11:58:01 PST 2015     root@build3.ixsystems.com:/tank/home/stable-builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.amd64  amd64
[root@freenas] /etc#  /etc/ix.rc.d/ix-smartd start
tail -n 10 /var/log/messages
Dec 15 16:42:38 freenas notifier: smartd not running? (check /var/run/smartd.pid).
Dec 15 16:42:38 freenas notifier: Will not 'restart' smartd because smartd_enable is NO.
Dec 15 16:42:55 freenas notifier: Starting smartd.
Dec 15 16:42:55 freenas smartd[8051]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries (like /dev/hda)
Dec 15 16:42:55 freenas root: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
Dec 15 16:42:55 freenas notifier: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
[root@freenas] /etc# cat /usr/local/etc/smartd.conf
# smartd.conf generated by /etc/ix.rc.d/ix-smartd
[root@freenas] /etc# camcontrol devlist -v
scbus0 on ahcich0 bus 0:
<>                                 at scbus0 target -1 lun -1 ()
scbus1 on ahcich1 bus 0:
<ST9160827AS 3.CMG>                at scbus1 target 0 lun 0 (ada0,pass0)
<>                                 at scbus1 target -1 lun -1 ()
scbus2 on ahcich2 bus 0:
<>                                 at scbus2 target -1 lun -1 ()
scbus3 on ahcich3 bus 0:
<>                                 at scbus3 target -1 lun -1 ()
scbus4 on ahcich4 bus 0:
<>                                 at scbus4 target -1 lun -1 ()
scbus5 on ahcich5 bus 0:
<>                                 at scbus5 target -1 lun -1 ()
scbus6 on camsim0 bus 0:
<>                                 at scbus6 target -1 lun -1 ()
scbus7 on umass-sim0 bus 0:
<TOSHIBA TransMemory 1.00>         at scbus7 target 0 lun 0 (pass1,da0)
scbus-1 on xpt0 bus 0:
<>                                 at scbus-1 target -1 lun -1 (xpt0)
[root@freenas] ~# smartctl -a /dev/pass0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family:     Seagate Momentus 5400.4
Device Model:     ST9160827AS
Serial Number:    5RF33NTY
LU WWN Device Id: 5 000c50 01477a9cd
Firmware Version: 3.CMG
User Capacity:    160,041,885,696 bytes [160 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5400 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 1.5 Gb/s
Local Time is:    Tue Dec 15 16:51:29 2015 CST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (  426) seconds.
capabilities:              (0x5b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      (  60) minutes.
SCT capabilities:            (0x0001)    SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   094   059   034    Pre-fail  Always       -       236187915
  3 Spin_Up_Time            0x0003   100   099   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   079   079   020    Old_age   Always       -       22240
  5 Reallocated_Sector_Ct   0x0033   098   098   036    Pre-fail  Always       -       102
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       4428332530
  9 Power_On_Hours          0x0032   066   066   000    Old_age   Always       -       30009 (184 176 0)
10 Spin_Retry_Count        0x0013   100   100   034    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       977
184 End-to-End_Error        0x0032   100   253   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x003a   001   001   000    Old_age   Always       -       2329
189 High_Fly_Writes         0x0022   001   001   045    Old_age   Always   FAILING_NOW 234
190 Airflow_Temperature_Cel 0x0032   065   036   000    Old_age   Always       -       35 (Min/Max 10/64)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1565
192 Power-Off_Retract_Count 0x0022   100   001   000    Old_age   Always       -       69
193 Load_Cycle_Count        0x001a   089   089   000    Old_age   Always       -       22922
194 Temperature_Celsius     0x0012   035   064   000    Old_age   Always       -       35 (0 10 0 0 0)
195 Hardware_ECC_Recovered  0x0010   066   047   000    Old_age   Offline      -       236190989
196 Reallocated_Event_Count 0x003e   066   066   000    Old_age   Always       -       30054 (30598 0)
197 Current_Pending_Sector  0x0000   100   100   000    Old_age   Offline      -       18
198 Offline_Uncorrectable   0x0032   100   100   000    Old_age   Always       -       18
199 UDMA_CRC_Error_Count    0x0000   200   200   000    Old_age   Offline      -       0
200 Multi_Zone_Error_Rate   0x0000   100   253   000    Old_age   Offline      -       0
202 Data_Address_Mark_Errs  0x0000   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 2333 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Error 2333 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
  ER ST SC SN CL CH DH
  40 51 00 5e a8 24 e0  Error: UNC at LBA = 0x0024a85e = 2402398
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 30 50 a8 24 e0 00      03:50:35.891  READ DMA EXT
  27 00 00 00 00 00 e0 00      03:50:35.890  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      03:50:35.884  IDENTIFY DEVICE
  ef 03 45 00 00 00 a0 00      03:50:32.252  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      03:50:32.252  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 2332 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
  25 00 30 50 a8 24 e0 00      03:50:24.956  READ DMA EXT
  27 00 00 00 00 00 e0 00      03:50:24.955  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      03:50:24.948  IDENTIFY DEVICE
Error 2331 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
  ef 03 45 00 00 00 a0 00      03:50:24.940  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      03:50:24.939  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 2330 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
Error 2329 occurred at disk power-on lifetime: 25099 hours (1045 days + 19 hours)
  25 00 30 50 a8 24 e0 00      03:50:17.477  READ DMA EXT
  27 00 00 00 00 00 e0 00      03:50:17.477  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 00      03:50:17.477  IDENTIFY DEVICE
  ef 03 45 00 00 00 a0 00      03:50:17.476  SET FEATURES [Set transfer mode]
  27 00 00 00 00 00 e0 00      03:50:17.476  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
# 1  Vendor (0x50)       Completed without error       00%         1         -
[root@freenas] ~# smartctl -d auto -a /dev/pass0
Local Time is:    Tue Dec 15 16:52:17 2015 CST
                    been run.
                    command.
                    power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   094   059   034    Pre-fail  Always       -       236187927
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       4428332551
  9 Power_On_Hours          0x0032   066   066   000    Old_age   Always       -       30009 (118 46 0)
195 Hardware_ECC_Recovered  0x0010   066   047   000    Old_age   Offline      -       236191005
196 Reallocated_Event_Count 0x003e   066   066   000    Old_age   Always       -       30054 (13572 0)
dash
That's because there isn't a solution. After much talk on the forums here and IRC.
Its just that the proprietary controller will never push SMART data to FreeNAS.
I ended up getting a LSI SAS9211 and reflashing it. I haven't had an issue since.
Sorry this isn't the answer you were looking for. But to be perfectly honest. If I had read the supported hardware first I would of never had any issues.
diskmaster23
I am sorry. I did not make it clearer, I am not using a controller (yet). It is still having trouble. I am using a Asrock Z77 EXTREME3 motherboard. Could that be an issue?
rogerh
I note the manual for that board claims: "ASRock Interactive UEFI is a blend of system configuration tools, cool sound effects and stunning visuals. Not only will it make BIOS setup less difficult but also a lot more amusing." But it does have software raid settings, are you sure they have all been disabled in the BIOS, amusing or otherwise?
diskmaster23
It does, but it wasn't enabled. Raid not enabled.
rogerh
Well your problem is well beyond my understanding, but it does seem to be a SATA driver problem of some sort, and somewhat different from the bug mentioned above, especially as this is apparently an Intel SATA controller on the board. (Is that right?)
I would suggest starting a new thread, and putting the details of your hardware (particularly all the disks the number of which is not clear to me at least). You will hopefully get the attention of the experts!
